Sponsored by: Innova
Factory DVD and Navigation system
Old Dec 10, 2006 | 09:17 PM
xtrm1stang's Avatar
xtrm1stang
I have a 2007 Expedition aith Factory DVD and Navigation. Is it at all possible to watch a dvd playing on the rear dvd system on the front navigation system screen, also can you bypass the 5mph/park system on the navigation system so you can have full function control of the nav system at speeds higher than 5mph?
Old Dec 14, 2006 | 08:55 AM
98x50's Avatar
98x50
The navigation issue might be able to be bypassed, but I have yet to hear of anyone figuring it out. I would think that someone will soon unless Ford/Pioneer were too darn clever. Aftermarket Pioneer nav units are generally pretty easy to bypass.
The video issue, from my research, is a lost cause. As configured the oem dvd units have audio outputs, but no video output. The factory radio/nav gets the audio of course, but from everything I have seen does not have any video input. You would need a way to get a video signal out of the the dvd unit and into the nav unit. The signal out of the dvd is actually easy, but going into the factory nav unit looks to be impossible. The unit needs a video input and a way to switch to it.
I ran into all of this trying to equip my 06' F-350 crew cab diesel with nav/dvd. Ford didn't offer either from factory and initially I wanted to use all factory items since they are pretty easy to find cheap on ebay. While I am still going to use a factory overhead dvd unit I have opted to run a Pioneer Avic-D2 for ease in accomplishing both of the issues you are running into. The factory dvd was WAY cheaper than an aftermarket rear dvd player/monitor and the Avic can be had for less than a factory nav unit. Ford gets $1995 for the nav and around $995/$1500 for the dvd. I'll be setup for less than half that, have full on the fly nav control with dvd in the rear AND on the nav unit.
Unfortunately you have alreay paid a pretty penny for the nav unit when you bought the truck, so yanking it out and replacing it might not feel like the best thing to do! Wish I knew how you could overcome the issues without switching head units. If you have any good stereo shops in your area check and see what they have run into with late model Ford nav/dvd setups. Some of these guys are very clever at work arounds for factory stuff.
Callmed
Sep 4, 2016 03:26 PM
fire3110
Dec 11, 2009 05:22 PM
Bucco63
Jul 12, 2009 06:20 PM
98explorerltd
Apr 27, 2009 03:42 PM
soundwave
2004 - 2008 F150
Apr 3, 2007 08:57 PM
