the one for the recall from Ford ('05 PSD) for cold start up or what ever it was for. Anyway now when I shut my truck off I hear (the fuel pump?) run for about 60 seconds after I get out of the truck. Is this a normal event with the new flash or is something else going on here?
My 06 PSD doesn't make this noise after shut down so I assume that the injectors are not purging. Is something different about the 06 that they don't need to cycle after shut down, or do I need a new flash? Thanks, John
i have an 06 ps and i just got the reflash that cycles the injectors for cold starts, sometimes i hear it when i shut the key off and sometime i dont here it........this new reflash is a good thing it will help those high dollar injectors to last longer.
the flash will cycle the injectors for 30 seconds after shutdown to purge oil out of injectors. as stated above this is supposed to help cold start and make the injectors last longer by purging the spool valves in the injector(helps keep them clean).
