Vin location help
Old Dec 8, 2006 | 07:19 PM
Racemaster33's Avatar
Racemaster33
Vin location help
I am buying a 68 F100 and need to know where to find the vin number. The truck is in a million pieces. The owner has three 68's and doesn't know which title matches the truck I want to buy. The other two trucks are not close by so we can't go by process of elimination. Also, the doors on the truck I'm buying are doner doors from another truck so cant use the door tag. Can somebody tell me where else the vin will be stamped? Also, where can I order a new door tag to match the title (once we figure out which one it is).
Old Dec 8, 2006 | 07:30 PM
merlynr's Avatar
merlynr
I understand that the vin # is on the top of the frame in engine compartment, but can't remember which side it's on. Maybe someone else knows for sure
Old Dec 8, 2006 | 09:45 PM
jrzoffroad's Avatar
jrzoffroad
The VIN is usually stamped on the passenger side frame rail. I have seen it up close to the radiator and as far back as underneath the cab. Take some carb cleaner and a rag with you to wipe off the area. As for replacement VIN tags, you are going to be out of luck on anything that old. Manufacturers will supply replacement door tags but they only go back about 5 to 10 years.
Old Dec 8, 2006 | 09:49 PM
Racemaster33
Thanks for the info. I'll go look at the frame rail tomorrow. I won't have to worry about cleaning it first, this is a 'frame-off' restoration job.
Thanks
Old Dec 9, 2006 | 06:26 AM
jowilker's Avatar
jowilker
Racemaster33, Welcome to FTE The nations truck stop
The vin is stamped into the top of the passenger side frame rail running lengthwise, about where the front axle passes under, and again under the cab. Sometimes they can be a little hard to dig out of the crud but it is there. Garonteee!
John
Rob C
25
Nov 6, 2020 05:10 PM
cndfarm99
21
Oct 11, 2014 04:34 PM
dbgphx
Aug 15, 2013 04:40 AM
cord4530
15
Oct 1, 2008 09:59 PM
Gwilkrrs
30
Dec 20, 2002 08:02 PM
