vin tags
Old Dec 12, 2002 | 04:28 PM
Gwilkrrs's Avatar
Gwilkrrs
vin tags
i know the vin tags should be on the glove box door or the door jamb.
my truck didnt have a glove box and the door jamb had nothing. the truck has been repainted so maybe they removd it. the only evidence of vin is on the title. where else can i look?
Old Dec 12, 2002 | 05:26 PM
Earl's Avatar
Earl
vin tags
Frame rails in front of the cab. Usually stamped on the top flange.
Old Dec 12, 2002 | 05:41 PM
Gwilkrrs's Avatar
Gwilkrrs
vin tags
does the body have to be off for that?
Old Dec 12, 2002 | 06:27 PM
56efffie's Avatar
56efffie
vin tags
if i remember right it should be visible without removing the front sheetmetal. There has been previous posts threads on this subject.:-X12
Old Dec 12, 2002 | 07:31 PM
Gwilkrrs's Avatar
Gwilkrrs
vin tags
thank you, ill try the search function if i can finsd it
Old Dec 12, 2002 | 09:54 PM
rebellforever's Avatar
rebellforever
vin tags
it would be on the passenger side in the wheel well.
i just fount mine the other weekend.
if you got a older truck there should be a plate on the inside of the engine compartment.
above the battery tray.
got a 49 and a 51 cab.
49 frame also that matches cab.
if you got the vin you can buy plates for your glove box and that.
all you would have to do is have them punched.
swanny
Old Dec 14, 2002 | 08:00 AM
Gwilkrrs's Avatar
Gwilkrrs
vin tags
thanks ill be looking.
Old Dec 14, 2002 | 03:29 PM
alaskanf1's Avatar
alaskanf1
vin tags
Rebellforever - I'm missing my glove box tag also, where can I get a blank one? I've found a blank patent data plate, but haven't been able to find the other. Any hekp would be much appreciated.
alaskanf1
Old Dec 14, 2002 | 03:46 PM
rebellforever
vin tags
um.........
ill have t look in my books.
ill try to post it tonight before i go to bed.
im not realy sure.
ill get you the price also.
they are real cheap.
swanny
Old Dec 14, 2002 | 08:25 PM
Schoonie48F2's Avatar
Schoonie48F2
vin tags
Does anyone know if the '48 is also stamped on the frame? And where?
Old Dec 14, 2002 | 08:43 PM
alaskanf1's Avatar
alaskanf1
vin tags
I believe all the 48-52 (maybe latter and earlier too, not sure) trucks had VIN's stamped on the right frame rail adjacent to the engine mount and just in front of the shock.
alskanf1
Old Dec 15, 2002 | 10:42 AM
51dueller's Avatar
51dueller
vin tags
on the 48-52's the number is stamped by the steering box.
Nathan
Old Dec 15, 2002 | 03:20 PM
alaskanf1's Avatar
alaskanf1
vin tags
51dueller - That's weird, both my frames (both 51 f-1"s) are where I mentioned eariler. Is yours by the steering box? I wonder if it's different because yours is a mercury? Or maybe because it's bigger than an f-1? Or because ford felt like making the restorers life confusing? I noticed you have a 51 f-1 parts truck too, where is that one located? Not that I really care, just curious at this point.
alaskanf1
Old Dec 15, 2002 | 04:35 PM
51dueller's Avatar
51dueller
vin tags
Both trucks are in the same place and the M-3 also has it in the middle of the frame. Well maybe the canadians had to make it different.
Nathan TM
Old Dec 15, 2002 | 06:04 PM
Gwilkrrs's Avatar
Gwilkrrs
vin tags
i cvant find blanks for the 51 only 53 and on.
