turbo surge
Old Dec 8, 2006 | 09:42 AM
tjheavychevy's Avatar
tjheavychevy
turbo surge
anyone have this problem? Going about 55 or 60 with a steady throttle, the turbo seems to surge up and down 2 or 3 psi. Its wierd. It doesnt do it under a load just cruising.
Old Dec 8, 2006 | 12:33 PM
catalinagoose's Avatar
catalinagoose
Sounds like you need a new VGT solenoid. I've seen that problem on a few trucks.
Old Dec 8, 2006 | 02:40 PM
569104's Avatar
569104
I had this happening to my 04 6.0 as well. I took it to the dealer and they suspected an exaust pressure sensor that was under recall. They replaced it and did a re-flash and I have not had the problem since.
Old Dec 8, 2006 | 04:00 PM
tjheavychevy
Where is the exhaust pressure sensor located? I changed the fuel filters on my truck two days ago and found a sensor behind the fuel filter to be unplugged. I plugged it back in. I dont know if this has anything to do with it or not.
Old Dec 8, 2006 | 05:14 PM
569104's Avatar
569104
I don't know where it is, just know the dealer said there was a recall on it and so they replaced it.
Old Dec 8, 2006 | 05:26 PM
npccpartsman's Avatar
npccpartsman
EBP sensor--drivers side exhaust manifold very front top.
Old Dec 9, 2006 | 02:56 PM
Danno126's Avatar
Danno126
VGT accuator
Old Dec 10, 2006 | 07:13 PM
tjheavychevy
ok thats two for the vgt actuator and one for the ebt sensor. Is there any other problems that would be happening with the failure of either sensor or accuator? something to narrow the problem child down to?
Old Dec 10, 2006 | 07:31 PM
Renagade 306's Avatar
Renagade 306
tj , does the motor get a little louder or does the boost just go up? My motor just started today surgeing a little. gets louder and quiter
Old Dec 10, 2006 | 07:46 PM
tjheavychevy
well, it is picking up the rpms with it so it might get a little louder but for the most part it is staying pretty normal.
Robert6401
Nov 25, 2012 06:52 PM
crazymut
Oct 1, 2011 07:18 PM
THE KING
Oct 25, 2007 10:30 PM
blrman1962
Mar 25, 2007 03:49 PM
Briansshop
Dec 10, 2005 09:26 AM
