error code P1400
Old Dec 7, 2006 | 02:30 PM
walfam's Avatar
walfam
error code P1400
Hello,
About two weeks ago I replaced my DPFE sensor, when the CEL came on,
now I just got an error code P1400:Manufacturer Controlled Auxillary Emission Controls.
Can someone translate this into layman's terms?
Thanks,
Old Dec 7, 2006 | 07:55 PM
Rockledge's Avatar
Rockledge
You can look up the code HERE. Essentially it says that the P1400 code is caused by either a bad DPFE sensor or there is a problem with the DPFE wiring harness (grounded) somewhere in the circuit. So you'll want to check the harness and connector for any signs of distress.
However, I've also heard that a P1400 might also be set when the PCM reads a lower voltage than expected, and not necessarily just an out-of-range condition. In such cases a P401 code would be anticipated as well, but I suppose you never know. As such, it might be wise for you to check over the entire EGR system to the best of your ability, using the tips and suggestions put forth in this thread:
https://www.ford-trucks.com/forums/1...ufficient.html
HERE is a summary of the Ford EGR/DPFE system for further reference.
Old Dec 7, 2006 | 10:05 PM
walfam's Avatar
walfam
Thank you for your help
Old Dec 8, 2006 | 10:16 AM
pawpaw's Avatar
pawpaw
The P1400 code as my reference reads it, is for low VREF voltage to the DPFE sensor, for Ford & Mazda.
So, try pulling the DPFE electrical connector & check the reference voltage, between the two outside connections (VREF & DPFE) connections. It should be between 4.0-6.0 volts.
If it's low or non-existent it may be as Rockledge has suggested, a wiring problem, or a computer problem, as the computer generates the VREF signal, or even a low B+ voltage, from a weak battrey or acting out alternator, but seems to me if it were the latter, you'd likely have other problems too & you haven't mentioned any.
Just some more things for consideration.
Let us know what you find.
Old Dec 8, 2006 | 01:18 PM
walfam's Avatar
walfam
Thank you for your input, I'm going to mess around w/it on Sat.
bit422
Jul 16, 2009 09:22 AM
Rob.D
Dec 28, 2008 07:55 AM
dennisdoc
1997 - 2003 F150
Mar 20, 2008 09:56 PM
labtech
Oct 30, 2004 01:22 PM
