Startup idle....
Old Dec 7, 2006 | 09:59 AM
timbersteel's Avatar
timbersteel
Startup idle....
I'm just curious what is everyone's startup idle? I have (2) straight 6 fords, one '90 and the other '92. IT seems the '92 has a lot higher startup cold idle than my '90, and the '92 takes longer for the idle to come down. The '90 startup idle seems more comforting when it starts up cold, but the '92 feels a bit more uncomfortable. I'm just curious if anyone has major differences. The '92 has 98,000 miles and the '90 with 45,000. Also on the '92, I changed the IAC, ECT, TPS, and the ACT sender, maybe I should replace each one until I come back to my comforting idle on the '92.
The '92 idles at startup about 1800 to 2000 rpms, and the '90 around 1500 to 17 or 1800 rpms.
LEt me know what you guys come up with!
Old Dec 7, 2006 | 10:22 AM
brian.taylor's Avatar
brian.taylor
my 88 will idle as high as 2000 if its REALLY cold outside, but it will come down after about thirty seconds, or it I give it a little gas.
Old Dec 7, 2006 | 10:45 AM
timbersteel
My '92 does that but more often with every startup even when it's warm, or in comparison, my '90 not started in 2 days doesn't even startup as high as the '92 in the same cold weather. I think something may be wrong. I may just have to start troubleshooting each sensor I replaced.
Edmo
Modular V10 (6.8l)
Aug 7, 2022 04:29 AM
johnday
1983 - 2012 Ranger & B-Series
Oct 7, 2012 07:45 AM
Owl
Dec 12, 2005 10:29 PM
Highmark18
Oct 13, 2004 09:27 PM
supermottl
1978 - 1996 Big Bronco
Aug 12, 2003 12:16 PM
