Modular V10 (6.8l)
throwing a p0355,56, and 57 code
Old Feb 28, 2010 | 06:55 PM
f250dodgeater's Avatar
f250dodgeater
hey everybody new here and haven some problems. my 01 f250 with the v-10 was missing a lil bout a month or so ago but wouldnt do it all the time so didnt think anything of it well it has progressively got worse to the point it threw the p0355 code so i changed the coils plugs and the injectors ( the injectors cause my dads f150 had the same problem with no codes and it was an injector) and after doing this it threw the p0355,56, and 57 codes. it has a new optima yellow top and a newish alternator and the battery light flickers on and off. I told a friend about it and he said it was a voltage regulator and i havent changed it, could this be the root of all the problems? somebody, anybody help please!
Old Mar 1, 2010 | 02:35 PM
scraprat's Avatar
scraprat
Top Answer: 5
Recheck your coils. Make sure there tight. Disconnect your Battery to clear the codes. Check the battery connections.
P-0355 Ignition coil E primary/secondary circuit malfunction (#5)
P-0356 Ignition coil F primary/secondary circuit malfunction (#6)
P-0357 Ignition coil G primary/secondary circuit malfunction (#7)
Tile man
2004 - 2008 F150
Apr 18, 2017 08:51 PM
hillpls
Jan 28, 2017 08:22 PM
Austonpond
Computer Chips & Tuners
Sep 7, 2016 10:06 AM
nightflight
Mar 21, 2013 10:57 PM
Oldyella66
1997 - 2003 F150
13
Aug 24, 2011 01:12 AM
