Sponsored by: Auxito
shifting problems into 4x4
Old Dec 5, 2006 | 06:01 PM
tbill68's Avatar
tbill68
1997 F150 manual shift. When trying to shift into 4high or low shifting is very stiff and most times won't go into either. If I move shifter back and forth several times once in a while it goes in, what up with that.
Old Dec 5, 2006 | 07:02 PM
Wilber15's Avatar
Wilber15
Try disconnecting the linkage to the Transfer case and lubing it up. My brother had the same problem on his 97' 4x4 and when he brought it to the dealer they lubed it and it's worked fine since.....
Old Dec 6, 2006 | 12:32 AM
preppypyro's Avatar
preppypyro
I lubed mine up recently and it has worked awesome. Good advice wilber.
Old Dec 6, 2006 | 07:50 AM
tbill68's Avatar
tbill68
thanks for the info
Have lubed linkage several times and works for awhile. Any other suggestions out there. Maybe replace shifting linkage?
Old Dec 6, 2006 | 07:54 PM
metal13x's Avatar
metal13x
my dad had the same problem (97 4x4), i think he took it in and had it lubed up or adjusted or something. If the lubing doesnt work, i would take it in to see if you could get it adjusted, then if that is a no go have it replaced. Ill ask my dad what the dealership did to make his shift smoothly.
