Remote Start Shut Down
Old Dec 3, 2006 | 04:24 PM
2funride's Avatar
2funride
Hi all!
First off, what a great site! I am a newbie 7.3 owner in a 2003 Excursion that came with a Code Alarm remote start which works fine except for one little issue.
After remote starting and idling for a few minutes the motor goes into it’s usual higher idle, however this causes the truck to shut off.
Has anyone else had this issue? I believe it might be something in the alarm that has to be re-programmed to allow for a broader allowable RPM range to be accepted.
In testing, it will shut off the same way if after started you just step on the throttle.
I’m pretty sure it is some kind of safety/theft device in the software.
Any ideas will be much appreciated.
Thanks in advance, I can see this forum saving me tons by not going to the dealer for all I am reading here.
Thanks,
Paul
Old Dec 3, 2006 | 04:28 PM
shenders99's Avatar
shenders99
It is not a safety/security function as that code alarm is the unit that the factory uses and no one else has the same problem. Typically the security switch is the brake.
Who wire this system? Was it factory, maybe a tech with no diesel alarm experience did it.
Some else should have more to add to this.
Old Dec 3, 2006 | 04:36 PM
lancer's Avatar
lancer
It does sound like it may be some sort of rpm safety thing. I would read in your owners manual and see if it tells how to arm and disarm the alarm. I'm sure theres some trick to it!
Old Dec 3, 2006 | 05:27 PM
Green_Dually's Avatar
Green_Dually
Just a shot in the dark here,but maybe your shock sensor is activated and sensing movement and turning the truck off.
I had this problem on one of my cars,only difference is my alarm would sound when it happened.
Old Dec 3, 2006 | 05:46 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Sounds exactly like the shock sensor. Turn down the sensitivity, there should be a small **** on the side of the unit, counter clockwise should do it.
Grinder Man
Oct 10, 2014 09:35 AM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
jetact
Sep 14, 2010 09:30 PM
jpj64
1983 - 2012 Ranger & B-Series
25
May 24, 2010 08:58 PM
Technocrsr
Jun 6, 2007 08:27 PM
