Its done !!!! What a long road.
First of all THANK YOU to everyone that helped with parts numbers to advice. Today especially when we were not sure we had done the right thing. Thanks to all the techs that give your time freely with nothing but our extreme gratitude in return. You all have my deepest respect.
This started over 3 weeks ago. it obvious we were in no hurry as we worked on it in our shop when we had time. My brother did most all of the work and I thank him as he is our diesel mech. Had all of the parts before starting but of course I missed a gasket and has a wrong part for the water pump. All in all a HUGE learing experience. We pulled the motor as that the way he likes ot work on the engines. He likes it best when he can just pull back the hood and the whole engine is sitting in front of him. Had the heads surfaced. They took off .005. Getting close ot the edge, but they are flat. Here is a list of all the parts replaced.
It sounds great and runs great. I am so happy to have it back. Only have 58,000 on the truck so it should be good for a few more.
EGR Cooler delete
Rebuilt Oil Cooler
Fuel regulator blue spring
Intercooler pressure tested and cleaned
Intake tanked
CCV reroute
Heads resurfaced .005 off, valve job and seals
Injectors tested and new orings
Intake, EGR, carrier gaskets
ARP studs
Victor Reintz head gaskets
Turbo oil feed tube update
Turbo drain tube update
T-stat
Upper and lower radiator hose
SCT fitting update
8 glow plugs
New water pump
New radiator
Turbo recondition
IRP valve
2 updated stand pipes
2 Dummy rail plugs
Degas bottle cap
HCFM drain plug
CAC boots
New map sensor
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Switched to Mobil 1 Turbo Diesel Truck 5w40
Fleetrite ELC
EGR Cooler delete
Rebuilt Oil Cooler
Intake tanked
CCV reroute
ARP studs
T-stat
SCT fitting update
8 glow plugs
New water pump
New radiator
Turbo recondition
IRP valve
2 Dummy rail plugs
Degas bottle cap
HCFM drain plug
CAC boots
New map sensor
<o></o>
Fleetrite ELC
websurfer
1997-2006 Expedition & Navigator
19
02-21-2024 06:19 PM
AZRogala
Computer Chips & Tuners
17
12-11-2015 04:30 PM
clarkbre
04-28-2014 10:40 PM
Stumpman
07-25-2011 10:05 PM
