Bronco II Ford Bronco II
Bronco ii Elec promlems Help?
Old Dec 3, 2006 | 03:28 PM
Spook10165's Avatar
Spook10165
I have an 87 Bronco II 4wd. It will not start. I have narrow the problem down to getting fire. It is not getting fire to the coil. I have replace the ICM, ing coil, fuel pump relay, ing relay and starter relay and still nothing. What else is left? What is it I am missing.
Old Dec 3, 2006 | 10:58 PM
Dealford's Avatar
Dealford
Welcome to FTE !!!!!
Pull the right side kick panel off and check the connections at the computer. If there's any sign of corrosion or water damage, you might have a problem like I did. The pin on my computer that feeds the TFI module was corroded badly and actually came out of the computer with the plug.
Read this... http://www.asashop.org/autoinc/dec2002/techtotech.cfm
This no start nightmare has been brought up many times with a variety of solutions. Unfortunately, the search feature here at FTE is down for major service so you'll have to look through all the previous pages to find info.
You might want to look at the Ranger board as well considering the older ones had the same ignition system.
There is an Electrical Systems/Wiring forum here at FTE as well. Just a little further down the main index.
AL.
Old Dec 4, 2006 | 05:33 AM
Dryfire152's Avatar
Dryfire152
wiggle the wires going to the coil while someone else turns it over.
Magic
1947 and Older Ford Trucks
Nov 16, 2011 03:45 PM
87BRIIXLT
Bronco II
Jul 15, 2010 08:50 PM
discolady57
Bronco II
May 3, 2004 02:41 PM
wayne1
1983 - 2012 Ranger & B-Series
Jan 29, 2004 11:02 PM
vug
Bronco II
Sep 14, 2001 09:00 PM
