Bronco II Ford Bronco II
87 bronco II electrical problems
Old Jul 12, 2010 | 03:04 PM
87BRIIXLT's Avatar
87BRIIXLT
Unhappy 87 bronco II electrical problems
FIRST POST EVER BY ME
alright guys i got a huge problem. my truck was running fine, i bought it like 4 months ago. i was haveing no problems. ran great and got me everywhere i need to go. well one day, about 2-3 weeks ago on my way to work, the truck shut off. out of nowhere. no warning signs no nothing. now i have gone through everything i could think of, now i come to yall and ask for some greatly needed help.
problems, there is a list
1. turning the key gives me nothing. no lights, nothing.
2. i have no fire from the ignition coil.
3. i have headlights, but no hazard or turn signals nor window (this truck is all power)
4.truck doesnt turn over, but when i go to starter cylinoide (sp) i can turn engine over, but like i said, no fire, no fuel to cylinders.
now what i have replaced:
1. the altenator went bad, so i replaced that
2.i replace the relay that is connected to the coil
3. starter switch i replaced a month ago.
4. did a recent tune up, also about amonth ago.
now finaly wht i think caused the problem, there is a wire they was bare that touched metal, it was the one between the ignition coil and relay, and i replace relay and the ignition coil is fine. now i am in a pickle. i was thinking about the distributor, but i am tired of pooring money into it and getting no resoults. PLEASE HELP ME!!!!!
i am tired of fighting with this truck, but i want to keep it. its my first bought vehicle!
Old Jul 12, 2010 | 04:19 PM
Lead Head's Avatar
Lead Head
Replacing parts by guessing is the last thing you want to do. If the thing won't crank, and a lot of electrical devices don't work, what makes you think a distributor of all things is going to fix your issue?
There are wires leading off the battery lead off the start solenoid. I don't remember 100%, but some of these wires have fusible links in them, they look like large rubber blocks in the middle of the wires. If the rubber link stretches when you pull on it - its bad. I'd start with these wires though, as these power your entire truck.
Old Jul 12, 2010 | 04:38 PM
87BRIIXLT's Avatar
87BRIIXLT
the altenator i took to nappa and they said it was bad. the fusible links were the first thing i checked. i was think distibuter cause the plug to the ignition coil had 2 wires. one to the relay i replaced and one to the distributer. i had a buddy come over and he is good at electrical stuff and he was confused by it, so was my dad. i am deffentaly confused. i am now just following the wire from where it touched bare metal to wire to where ever i can find the problem :/
Old Jul 12, 2010 | 04:49 PM
Lead Head's Avatar
Lead Head
A distributor would not cause a no crank situation. It would cause a no-start or poor running, but not a no crank.
Now the manual for my 1987 Ranger indicates that there are 8 fusible links.
It says for the ignition switch, there is a 16 gauge fusible link on the left hand fender inner panel.
The EEC-IV processor relay fusible link is a 20 gauge link near the starter solenoid.
Old Jul 12, 2010 | 04:54 PM
87BRIIXLT's Avatar
87BRIIXLT
yeah that one was bad and already replaced it. if it help ya think, i got the same truck as you. 1987 bronco II xlt 2.9 v6 automatic. my buddy went to the right hand side from drivers seat and touched a scre driver between 2 screws on silionde and that is the only way itll turn over, but like i said no spark nor fuel. key was on while doing it to, but i get no response no matter what i do with the ignition switch
Old Jul 12, 2010 | 05:30 PM
87BRIIXLT's Avatar
87BRIIXLT
i am really close to taking it to a place to get it checked out, but i dont wanna spend the money to tow it over there and to have them look at it.... and i like learning things. but this is alot harder than i thought.
Old Jul 14, 2010 | 08:21 AM
87BRIIXLT's Avatar
87BRIIXLT
new diagnostic review...
i have no power to my igition switch... i followed one of the 2 battery cables to a device that looks just like a hard drive of a computer. cant figure out how to put a picture on this thing... but its really weird and i think that it might be a problem. its not the ecu...
Old Jul 14, 2010 | 09:55 AM
rebocardo's Avatar
rebocardo
Sounds like an anti-thief device.
Old Jul 14, 2010 | 06:50 PM
87BRIIXLT's Avatar
87BRIIXLT
guys thanks but i finally figured it out. it ended up beign a fusible link that i never found till i followed a wire from my battery. she purs like a kittne now
Old Jul 14, 2010 | 07:24 PM
Lead Head's Avatar
Lead Head
Told ya you gotta make sure you check all those links!
Old Jul 15, 2010 | 08:34 AM
rebocardo's Avatar
rebocardo
Great. Though I would not mind knowing what that box is. :-)
Old Jul 15, 2010 | 08:50 PM
87BRIIXLT's Avatar
87BRIIXLT
haha i want to know to. if it has to do something with the ac that would be nice. cause its not blowning freezing cold air, just a little cold, and i recharged the system.
and as for that link.. i thought i did lol. it was hidden from me! it was practicly under the washer fluid and collent container!!
GYSOT250
Jan 15, 2017 03:12 PM
KShults
Oct 4, 2016 07:40 AM
Mike in Ohio
Jul 3, 2016 12:44 PM
Corey Beckwith
1997 - 2003 F150
Apr 29, 2016 07:40 PM
gurinder_s_gill
18
Dec 14, 2015 01:43 PM
