overdrive or not
Old Nov 26, 2006 | 05:28 PM
jakeh41's Avatar
jakeh41
overdrive or not
When pulling a trailer with my 99 powerstroke with an auto should can I drive with the overdrive on or not? Thanks
Old Nov 26, 2006 | 05:42 PM
bigtorque's Avatar
bigtorque
i tow the highway with it on, and in town off.........towing 14 K.
Old Nov 26, 2006 | 05:59 PM
mud rat jr.'s Avatar
mud rat jr.
I run mine in od until it starts downshifting alot or trans temp starts to climb or pyrometer starts to go to no mans land,we have a few passes to climb around here in any direction I can go to get to lower ground. also I take it out of od going down said passes when speed gets above about 70mph
Old Nov 26, 2006 | 08:57 PM
Ford RV'er's Avatar
Ford RV'er
OD on....on the flats. OD off....on the ups and downs. I pull 13k 5'er.
Old Nov 26, 2006 | 10:20 PM
aklim's Avatar
aklim
Is the trans hunting? IOW, is it shifting between OD and D very often? If so, set OD to off. If not, continue with OD
Old Nov 26, 2006 | 11:14 PM
Pocket's Avatar
Pocket
Constant shifting in and out of O/D while towing a load will heat up the tranny.
Also, lugging the engine with a load will raise EGT's.
So..... If it's constantly shifting, or the engine is lugging, lock out O/D. Otherwise, you're safe.
Old Nov 27, 2006 | 01:08 PM
jakeh41's Avatar
jakeh41
When out of OD the engine runs at the higher RPM's is this causing any damage to the engine or just eating more fuel? Also how much does a typical temp gauge for the tranny cost? Probably need one if I am going to pull with the Overdrive on right.
Old Nov 27, 2006 | 01:11 PM
jakeh41's Avatar
jakeh41
also can you click the OD on/off on the go? New to the auto use to the manual. Thanks
Old Nov 27, 2006 | 01:29 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The higher RPMs will not hurt the engine....in fact, it is better for it. Lugging the engine just creates exhaust heat and load due to the accelerator pedal being pushed farther into the carpet to maintain speed.
If I'm pulling a load, I will turn the OD off because I'll usually be pulling at 60-65 MPH tops.
Switch as you please on the go.....just be sure you're not doing 75 when you turn OD off.
Cody
Old Nov 27, 2006 | 08:17 PM
aklim's Avatar
aklim
I tow 8500# RV with my Ex. Large sail area. I leave it on OD all the time and it doesn't hunt. Also look at my EGT gauge to see what the engine is doing. Unless it hunts, I don't switch off OD. Asked BTS about it and they said the same thing.
Kenworth
All Things Towing
Jan 13, 2003 01:50 PM
Sunfire_Stomper
Nov 5, 2002 03:31 PM
Yeti
Aug 28, 2002 10:38 AM
wolfmanagh
Apr 23, 2002 07:53 PM
ladani
1997 - 2003 F150
Jul 12, 2001 03:54 AM
