Sway Bar End Links
Sway Bar End Links
DOES ANYBODY KNOW IF THE REPLACEMENT SWAY BAR END LINKS THAT ARE MADE BY MOOG FOR A 1999 SD 4WD HAVE GREASE FITINGS ON THE LINKS ? i HAVE ALWAYS HAD TO USE SOME KIND OF SPRAY LUBE ON THE LINKS TO KEEP THEM FROM MAKING NOISE. iF THE MOOG PARTS HAVE GREASE FITTINGS THIS WOULD SOLVE MY PROBLEM.THANKS.
MR. DAVE - I checked and from the picture they show, http://www.autopartsgiant.com/CAT_FRAMEX.cfm No, they don't have a grease fitting, and the Moog Sway bar link kit #80041 sell for $ 12.19 per link. I brought a set of Fords oem for $36.00 this past spring because they and them in stock.
