panel door window install
Old Nov 26, 2006 | 12:44 PM
cabby daddy's Avatar
cabby daddy
do you install the window from the inside, or the outside?
i have the new window seals from bob drake, and cant decide which way is correct. does the "flap go to the inside, or the outside?
Old Nov 26, 2006 | 01:36 PM
bobj49f2's Avatar
bobj49f2
Here is the page out of the truck manual dealing with the installation of the rear window in a conventional cab, I would assume it's basically the same as the panels rear window. Unfortunately, I haven't gotten to that part of either of my panels yet.
Old Nov 26, 2006 | 05:07 PM
theGman's Avatar
theGman
Inside....
Old Nov 26, 2006 | 07:14 PM
cabby daddy
well then i installed correctly//// well kind of.... 1 looksgreat, the other well. it looks ok, except for the cracks....
going to order a new piece tomorrow,,,
Old Nov 26, 2006 | 07:17 PM
cabby daddy
oh yeah.... there is a difference in the lower and upper hinge
the upper is straight from the eye to the back of the hinge, and the lower is bent at a slight angle. just a very slight, but big difference when hanging the doors.
Old Nov 26, 2006 | 08:39 PM
bobj49f2's Avatar
bobj49f2
Bob.
I was checking out your gallery and saw you installed your driver's side running board. I know I asked about it before, but did you have to loosen up your fender before installing the board? The panel I bought last summer didn't have the board installed and it going to be next summer project after I paint the truck a better color of to match my F-2.
Old Nov 27, 2006 | 02:08 AM
cabby daddy
no i did not loosen the fender, but did loosen the body mounts, and used the porta power to lift the body about 1.5 " off the frame..... board slipped right in.
and thank you again for the parts.
Old Nov 27, 2006 | 07:28 AM
bobj49f2's Avatar
bobj49f2
You're welcome.
It doesn't sound like too much work to slip the board in concidering I have pulled the entire bodies off a few panels. It only took about six hours to swap the bodies between the two panels I have.
Thanks
MrF-1
Jul 27, 2006 12:21 AM
Rufus0415
Jul 21, 2006 02:38 PM
turboale
Jul 21, 2006 12:41 AM
dcexplorer
General Automotive Discussion
Apr 6, 2004 01:17 AM
dcexplorer
24
Aug 7, 2003 06:26 PM
