Here is the page out of the truck manual dealing with the installation of the rear window in a conventional cab, I would assume it's basically the same as the panels rear window. Unfortunately, I haven't gotten to that part of either of my panels yet.
oh yeah.... there is a difference in the lower and upper hinge
the upper is straight from the eye to the back of the hinge, and the lower is bent at a slight angle. just a very slight, but big difference when hanging the doors.
I was checking out your gallery and saw you installed your driver's side running board. I know I asked about it before, but did you have to loosen up your fender before installing the board? The panel I bought last summer didn't have the board installed and it going to be next summer project after I paint the truck a better color of to match my F-2.
no i did not loosen the fender, but did loosen the body mounts, and used the porta power to lift the body about 1.5 " off the frame..... board slipped right in.
It doesn't sound like too much work to slip the board in concidering I have pulled the entire bodies off a few panels. It only took about six hours to swap the bodies between the two panels I have.
