9" Tag question
Old Nov 26, 2006 | 12:27 AM
428cobrajet's Avatar
428cobrajet
Question 9" Tag question
I found the tag on my 9" rear but I can't find any spec's that match up to get the ratio. I done the spin a axle and count deal but I just want to make sure before I install it. It's muck easier to work on out of the truck. The # I have is 758 DA 88 and it came from my 68 Torino GT. There is a second set of 3 or 4 letters that are worn down is this the ones I need?
Old Nov 26, 2006 | 06:27 AM
4tl8ford's Avatar
4tl8ford
This page has about the best information on 9" that I have found.
All the ID's I've seen need the letters.
Clean the tag real good, put a piece of paper over it and do the pencil rub thing.
Old Nov 26, 2006 | 08:57 AM
havi's Avatar
havi
I'll have the Roast Duck
the lower row of numbers starting on the left is the ratio. I think 4tl8ford forgot the link?
Old Nov 26, 2006 | 12:43 PM
428cobrajet
The other letters are WEB H1. I don't see a link either. Thanks for any info
Old Nov 26, 2006 | 02:38 PM
4tl8ford's Avatar
4tl8ford
OOOOOOOOPS
http://www.enjenjo.com/9inch.html#3rdmember
Old Nov 26, 2006 | 02:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If you can find a link...the WEB-H1 will tell you almost everything you need to know...ratio, axle splines..etc.
It may not tell you whether it's a limited slip...on those axles, a separate tag was sometimes used...with a simple L meaning limited slip.
The first group of numbers you posted are some sort of assembly/engineering numbers...I forget what they refer to, sorry.
Old Nov 26, 2006 | 03:06 PM
4tl8ford's Avatar
4tl8ford
Jet
I've checked all my 9" stuff can't find WEB-H
Could you code be WES-H, that would be 3.50:1
Old Nov 26, 2006 | 07:09 PM
428cobrajet
I double checked the tag and it is WEB-H. I have checked every site I can find and same here no match. Everything on that car has been odd thats why I originaly bought it and restored it. The count with turning the tire says its a 2.75. Thanks for the help
Steve
Old Nov 27, 2006 | 04:30 AM
NumberDummy
Jet
Just thought about this...are you sure that the letters aren't WER-H?
If so...you have an 8.7 rear end, not a 9 incher.
Old Nov 27, 2006 | 07:33 AM
53C6_400ci's Avatar
53C6_400ci
I also have a question about this "Tag". I'm restoring a 1953 F100. The truck came with a 1971 400ci engine, a 1971 C6 transmission, and I'm not sure what rear end. It doesn't appear to be either a 9" or 8". From some catalogs it appears to be an 8.8, but I'm seeing conflicting info on that also.. 8.8's came out in 1983 or so? Any ideas?The cover has 10 bolts and 2 little notches cut out at 5 o'clock, and 7 o'clock position.
Thanks..
Old Nov 27, 2006 | 10:46 PM
NumberDummy
The only two rear ends available in 1971 for that powertrain are the 8.7 which had a rear cover, and the 9 inch dropout.
If there is a rear cover on the axle assy...it's an 8.7. The gasket part number is C7AZ-4036-A
The original tag code began WER-
4601ton
Jan 7, 2012 09:48 PM
92nite351
Jan 9, 2011 05:24 PM
67nukeford
Sep 25, 2009 12:27 PM
cac91
Feb 14, 2003 01:34 PM
1964Ranchero
Sep 25, 2002 06:59 PM
