engine interchangeability
Old Nov 22, 2006 | 08:30 PM
mike manglos's Avatar
mike manglos
Question engine interchangeability
what engine(s) would work in my 1993 ford IDI turbo diesel powered F-250 4x4
pickup truck?
Old Nov 22, 2006 | 09:37 PM
bilder12's Avatar
bilder12
a 6.9 will fit, a 7.3 will fit and a factory 7.3 turbo diesel will fit. the power stroke wont without many changes and alterations in the electrical system. some guys have gone over to the cummins diesel with alterations.
Old Nov 22, 2006 | 10:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
mike manglos,
Welcome to FTE and the IDI diesel forum.
I would suggest something between an 85.5 6.9 and a 94 7.3 engine
Old Nov 23, 2006 | 08:27 AM
yamaguy's Avatar
yamaguy
If your going to do a swap I would go with a 7.3 not a 6.9. I think that a stock 7.3 has alot more power. not enough to make it a hot rod, but just that little bit more to allow you to get the job done. my .02
Old Nov 23, 2006 | 10:21 AM
Dave Sponaugle
Install the turbo off the original motor and the HP is no different.
A 6.9 is rebuildable without using sleeves.
A 7.3 is not rebuildable without using sleeves.
The HP difference is 10 HP on the stock fuel settings on the NA motors.
Old Nov 23, 2006 | 10:22 AM
CheaperJeeper's Avatar
CheaperJeeper
I'd go with the 6.9 - for longevity.
The 7.3s are prone to cavitation problems. The cylinder walls are so thin to start with that they are basically non-rebuildable as well. Sleeving also seems to be a problem with them. Right Dave?
The difference in power between the 6.9 and 7.3 is small and can be made up for in other ways. Want an engine that will last? Get the 6.9....
EDIT: Ya beat me to it by ONE minute Dave...
musickerns
1997 - 2003 F150
Nov 6, 2012 11:15 PM
xtreme150
Engine Swaps
Mar 12, 2007 10:48 PM
Gouber
Mar 8, 2005 10:59 AM
Brad 61
Jan 9, 2005 09:35 AM
fkvbab
Mar 2, 2004 12:22 AM
