water in engine
Old Mar 7, 2005 | 07:24 PM
Gouber's Avatar
Gouber
water in engine
1977 F250 4x4 351M Truck has been sitting for 4 years, the hood is on and the engine is all complete. The cow to hood seal is gone. There was water lying on the back of the intake. Any thoughts how the water got in the engine?
Thanks
Old Mar 7, 2005 | 07:31 PM
79 posi's Avatar
79 posi
Snow? Rain / wind?
Old Mar 7, 2005 | 07:56 PM
plowpusher's Avatar
plowpusher
did you check the oil does it have water in it if no then don't i wouldn't worry the hood to body is not water tight one thing I would do before even turing over with the starter is to prelube the engine seen wat to many fords spin mains because of dry crank from sitting for long periods
Old Mar 7, 2005 | 08:08 PM
Gouber's Avatar
Gouber
Yes there was water in the engine oil. I thought maybe the water lying on back of the intake got in some how. Sorry New to Fords.
Old Mar 7, 2005 | 08:50 PM
plowpusher's Avatar
plowpusher
dump the oil and pressure check the cooling system you could have a coolant leak into the motor did it ever freeze while sitting possibly with weak or no antifreeze ? did it have anti freeze in it or just plain water? is there anti freeze in the oil
Old Mar 8, 2005 | 10:59 AM
hdgapeach's Avatar
hdgapeach
You didn't mention how much water there was in the oil but if the weather conditions are right in your neck of the woods (and it sounds like it could be with the intake water puddles), you could have a considerable amount of condensation that has formed inside the block over a four year period. I would look at the coolant in the radiator to see if it is just water or if it has temp protecting coolant in it. If it's water only, you may have a cracked block.
rebar13
13
Oct 10, 2014 11:03 AM
Scratcher
15
Aug 29, 2011 08:28 PM
cstrack
1997 - 2003 F150
May 16, 2011 03:41 PM
86f350diesel4x4
Feb 18, 2003 08:27 AM
f150agogo
1997 - 2003 F150
Feb 8, 2001 08:41 AM
