Front Leaf Spring Drop
Old May 21, 2002 | 10:49 PM
55f100's Avatar
55f100
I need to know which leaf(s) to pull (front & back) in order to acheive a slight drop, I am trying to build a late 50's early 60's era custom truck I am on a budget so this seems to be the easiest way, but I do need advice, Which leaves and how many.......
Thanks
55f100
Old May 22, 2002 | 02:50 PM
29abone's Avatar
29abone
According to Mid Fifty's, keep #'s 1,3,5,7 and the main leaf. Reverse the eyes on the main leaf for approx 3" drop in front and 3 3/4" drop n rear.
Larry
Old May 22, 2002 | 10:17 PM
55f100's Avatar
55f100
Is This method using the stock springs, or using new reverse eye springs. Like I said I am on a very tight budget ..
Old May 23, 2002 | 02:35 PM
29abone's Avatar
29abone
If you don't reverse the spring eyes, the drop is :
Front=1 1/4"
Rear=1 1/2"
You can reverse the eyes yourself, by placing the mainleaf between two pieces of steel 2" to 4" apart and carefully peening uniformly along the spring untill it reaches the correct curvature in the opposite direction. Measure before starting or chalk the shape on the floor. If you do this you will have to remove the first 1 1/2" from the eye of the #7 leaf, the part that wraps around the main leaf eye.
Larry
Old May 23, 2002 | 06:41 PM
46fordtruck's Avatar
46fordtruck
I've been thinking of taking some leafs out of the springs on one of my trucks to lower it. What does taking those leafs out of the spring pack do to the strength of the springs? I would think by taking out those leafs that the remaining leafs would be taking more of the load? If it works and there's no problems then I'll do it. but the truck will be my daily driver for a few months, and I want to make sure I won't have any probs.
Gary
1946 pickup-ongoing project
1946 pickup-waiting for resto.
1947 pickup-parts truck
1957 Ford FL 500 Town Victoria
1970 Mustang FB-daily driver
1972 Olds Vista Cruiser-4 sale
1988 Bronco II-for sale
Old May 23, 2002 | 10:29 PM
55f100's Avatar
55f100
Thanks for the advice
Old May 25, 2002 | 05:22 PM
bobj49f2's Avatar
bobj49f2
Old May 27, 2002 | 08:06 AM
wosborn's Avatar
wosborn
I've had my '59 panel for 20 years. When I was young and desparate, I pulled a couple leaves out of the front end. The immediate effect was excellent, really attracted the chicks. Later, the rest of the leaves were overworked and worn out. This further motivated me to attend school, get a job and buy reveresed eye springs for the same effect. I believe these reveresed eye springs are now back in production (front only?).
