I have an excursion(01) an need to tow a bronco full size from buffalo ny to columbia mo (800mi) since uhaul says it weighs to much for a dolly or trailer
i was thinking of getting a tow bar ( the bronco is dead driving it is not an option)
I don't recall if the Excursion weighs more than the Bronco and that's the key here. I've pulled quite a bit of equipment and the key is always the weight. If the Bronco is heavier then NO WAY. When you try to stop it will try to push you down the road. The other opteion is to rent a bigger truck and I would stay away from U-HAUL any way as they always try to get you for more.
You can use a tow bar on that bronco safely, the transfer case can go into nuetral so there is no need to remove any driveshafts. Take a good look at the tow bar you would be using, make sure it will handle the weight. Why not rent a trailer to tie it down too? IMHO the trailer would be the safest.
i must not know the right people because i donot know anyone with a trailerand i cannot find a nother company that rents trailers in buffalo,ny
ps. this truck is free i would like to keep the price down getting tis out to my brother
If the Bronco is 4X4, slap the tranfer case in neutral, unlock the steering wheel, hook up a tow bar and be gone. You didn't mention a year for the Bronco, but there is no way a Bronco outweighs an Excursion, regardless of year.
Uhaul would not rent us a trailer to bring a 1970 F100 from Columbus to NY (about 450 miles) said it was too heavy and wouldn't fit. Went to another Uhaul dealer and said it was for a Crown Vic. The truck is in NY with no problems. Also check the swap sheets for a tow dolly (my brother bought one in Buffalo this summer for $100 with magnetic lights) or tow bar. Sometimes you can buy cheaper than renting.
The key to renting from uhaul (for trailers) is to not tell them exactly what you are using it for. The trailers are heavy enough, but if they don't like how you act they can deny renting to you (this info came from a freind that used to manage a uhaul store). Just be specific, tell them it is a Bronco II that only weighs 3500#. Make sure that you have enough insurance on your vehicle to cover everything if for some reason there was a problem.
I'd look really hard at buying a tow dolly for the move & then reselling it when you are done with it. Buy used off e-bay & sell the same way.
Cost should end up being cheaper then renting one way from U-Haul.
i went to a moterhome place and found a used tow bar for $35 SOLD!!!! i have a friend looking at the autobody shop for some lights. as you can tell my budget is free or almost free
If I was you I would disconnect the drive shafts before towing it that far. That will protect the trans no matter what 4x4 system you have. Besides it may reduce the drag on the Bronco and net you a 1 gal savings in fuel for your trip.
I would disconnect the drive shafts also. I understand Jeep offers neutral shifting of the transfer case for towing, but I don't think it applies across the board.
Disconnecting the drive shafts is a very good idea. It will save wear on the transfer case AND gas mileage. You can put the transfer case in neutral and that should be fine but before I set out on an 800 mile trip I would check the fluid in the transfer case.
Flat towing I think is better than a tow dolly. Be sure that the Bronco has good tires and wheel bearings. The Excursion should have plenty of brakes to stop the Bronco is you use your head.
I tow cars on a tow dolly and, frankly, I frequently wish I'd gone the tow bar route instead - except for one point: the tow dolly has brakes. (Well, that, and one of the cars can't be flat towed.)
I know you didn't ask about this, but watch your brakes. You're going to be loading them a lot more than you're used to, and they'll get hot. After a couple people pull out in front of you, causing you to jam them on repeatedly, they'll overheat and could fail. (Personal experience. Fortunately I didn't hit anyone and was able to pull off and wait until they cooled off.)
well my first trip using the tow bar was getting rid of my uncles international travelall well it was more of a trade paul's bronco for my uncles international, ( Hmmm my brother gets the bronco paul gets the international what i get???) nyc to buffalo
all went well after the rust burned off the travelall's breaks. i was a little worried seeing smoke pouring out the front wheels ....20 min letting them cool everything was fine
