1966 - 1977 Early Broncos
Towing a Bronco
Old Sep 26, 2005 | 09:58 PM
okst1's Avatar
okst1
Towing a Bronco
I have a 1973 Bronco with 302 and C4 transmission. I recently installed twin sticks to replace the J shifter. I want to install a tow bar on the front of the Bronco to pull it to the deer lease. The Bronco Owner's manual says to put the Transmission and the Transfer Case in Neutral but it still requires that I remove the rear drive shaft. On my 1995 Bronco with 302 and E4OD transmission, the Owner's Manual says to put the Transmission and Transfer Case in Neutral but does not require that I remove the rear drive shaft. Why is their a difference in towing requirements?
Old Sep 26, 2005 | 11:05 PM
fordborn's Avatar
fordborn
You will want to pull the read driveshaft, and might want to get a dummy yoke to stick back in for towing or tie the shaft up under the Bronco. The problem is the C4 won't pump oil without the input shaft turning so it's about like running dry.
Old Sep 27, 2005 | 03:57 AM
mauicruza's Avatar
mauicruza
If you shift a transfer case into neutral, doesn't that disconnect the t/c's output shafts from the input gear? If so, then it wouldn't turn the C4s inards, right??
Old Sep 27, 2005 | 09:04 AM
okst1's Avatar
okst1
Maui, that's what I thought. If there is no connection between the transfer case and the transmission, how can the transmission turn? To me, that is no different than the front differential being in neutral.
Old Sep 27, 2005 | 09:56 AM
fordborn's Avatar
fordborn
Putting both the transmission and the transfer case in neutral will according to some people be good enough to make it tow-able. It's really a topic that will get about as many for as against removing the driveshaft. I just happen to be one that prefers the added safety margin of removing it. If the manual says to remove the shaft then I figure they should know and when in doubt follow the manual.
Old Sep 27, 2005 | 05:46 PM
okst1's Avatar
okst1
Thanks Fordborn, where would I get a dummy yoke or do I need to make one?
Old Sep 27, 2005 | 06:16 PM
fordborn's Avatar
fordborn
We alsways just made ours by using an old one.
Old Sep 28, 2005 | 07:53 PM
captradiator's Avatar
captradiator
While I am certainly not an expert, I have read that the very best thing to do is convert the real axle to have manual locking hubs.
Old Sep 28, 2005 | 08:13 PM
fordborn's Avatar
fordborn
Now that is interesting. I would like to hear more about doing that.
Old Oct 4, 2005 | 08:13 PM
2classics's Avatar
2classics
If you wheel hard, this would be another weak spot.
broncoman87
Bronco II
Mar 28, 2015 07:55 AM
pdqtimetrialer
1978 - 1996 Big Bronco
Sep 8, 2011 07:07 PM
andydorita
2004 - 2008 F150
Aug 24, 2005 11:22 AM
ecsmith0624
All Things Towing
Jul 1, 2004 09:07 PM
GendoIkari69
Jan 22, 2002 03:10 PM
