light switch removal
Old Jun 15, 2002 | 04:57 PM
19F10059's Avatar
19F10059
HOW do you go about removeing the dash bezels and switches in my 59 found nuts on the back of air vents but the headlite switch wiper switch and heater has me stumped no set scerws that i can see help what am i missing:-X11 THANKS TERRY
Old Jun 15, 2002 | 08:10 PM
mercuryblues's Avatar
mercuryblues
[updated:LAST EDITED ON 15-Jun-02 AT 09:11 PM (EST)]the headlite switch has a spring loaded button on the switch behind the dash.pull switch to headlite on position push button and **** and shaft come out as a unit.I'am sure others have set screws.
Gary
1959 M100
1970 T-Bird
Old Jun 15, 2002 | 09:27 PM
Kenny's Avatar
Kenny
Hi ,
The headlight switch comes out just like gary said. To remove the bezels however, you have to use a special tool. (You could probably just use a screwdriver, but will most likely chew up your bezels). I made one of these out of tubing. Almost like a screwdriver with a hole in the center. First you have to remove the ****. Stick the tubing over the switch's shaft, with the two "ears" in the slots of the bezel's threaded center piece. Then you just unscrew it. Ford actually had a tool just for this purpose (Tool-17470N).
Hope this helps.
Old Jun 16, 2002 | 01:33 AM
Jim G's Avatar
Jim G
john fin
Jan 9, 2020 10:19 AM
SeaCarr
Oct 21, 2013 02:16 PM
Badmrscary
Feb 15, 2011 04:57 PM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
Unclemuck
Feb 19, 2005 05:19 PM
