HOW do you go about removeing the dash bezels and switches in my 59 found nuts on the back of air vents but the headlite switch wiper switch and heater has me stumped no set scerws that i can see help what am i missing:-X11 THANKS TERRY
[updated:LAST EDITED ON 15-Jun-02 AT 09:11 PM (EST)]the headlite switch has a spring loaded button on the switch behind the dash.pull switch to headlite on position push button and **** and shaft come out as a unit.I'am sure others have set screws.
Hi ,
The headlight switch comes out just like gary said. To remove the bezels however, you have to use a special tool. (You could probably just use a screwdriver, but will most likely chew up your bezels). I made one of these out of tubing. Almost like a screwdriver with a hole in the center. First you have to remove the ****. Stick the tubing over the switch's shaft, with the two "ears" in the slots of the bezel's threaded center piece. Then you just unscrew it. Ford actually had a tool just for this purpose (Tool-17470N).
Hope this helps.
