'88 externally balanced
Old Nov 19, 2006 | 07:26 AM
djmac's Avatar
djmac
I recently bought a 460 long block on ebay. It arrived pretty much in great shape including the harmonic balancer shipped loose but no external balance weight. The PO says it did not have one. My believe that all '88 Fuel Injected motors were externally balanced. What do you think?
Old Nov 20, 2006 | 03:34 AM
RTM's Avatar
RTM
Yes it should have one. Double check the casting date on the side of the block by the starter.
Old Nov 20, 2006 | 05:11 AM
djmac's Avatar
djmac
Thanks, if I have to get a replacement are the hatchet all the same or did they vary year to year?
Old Nov 20, 2006 | 05:56 AM
RTM's Avatar
RTM
They're all the same. Just make sure some one didn't swap in a pre 78 bottom end/block.
Old Nov 20, 2006 | 08:26 AM
djmac's Avatar
djmac
Thanks, I'll do that.
Old Feb 18, 2007 | 09:20 PM
djmac's Avatar
djmac
The casting number is consistent with the external balancer. Could a pre '78 crank be installed in this block? If so how can I verify the crank vintage of the crank?
Old Feb 18, 2007 | 09:23 PM
monsterbaby's Avatar
monsterbaby
the early cranks will not fit in the late model blocks without clearencing, you can put the late model external balanced cranks in early blocks but not vice versa.
Old Feb 18, 2007 | 10:44 PM
djmac's Avatar
djmac
Thanks, I guess I better go shopping for a balancer.
Old Feb 19, 2007 | 08:57 AM
monsterbaby
not a balancer just the hatchet spacer, the dampners are the same either internal or external it's just that spacer that goes behind it.
BTW I am pretty sure you can still buy them new from Ford.
Old Feb 19, 2007 | 10:35 AM
djmac's Avatar
djmac
Thanks again!
JB78f150
Jun 1, 2012 01:20 AM
bigdan1979f-250
Dec 7, 2011 06:44 PM
Nathan
Nov 15, 2002 05:47 PM
Nathan
Jun 15, 2001 05:58 PM
wade_1
Nov 11, 2000 11:44 PM
