Internal or external Balance?
Old Apr 19, 2012 | 03:31 PM
JB78f150's Avatar
JB78f150
Need to know if my engine is an internal or externally balanced engine?
How do I find this out?
Old Apr 19, 2012 | 04:20 PM
monsterbaby's Avatar
monsterbaby
look above the starter for a casting number. If it's D9TE it's external balance, any other number is internal.
Also you can look behind the harmonic dampener. If you see a hatchet weight, external, if you only see a round spacer internal.
Old Apr 19, 2012 | 04:43 PM
JB78f150's Avatar
JB78f150
Ok, so it is an internal. I have a 351m bell housing. Np435. What do I need to do to mate them up? What clutch will work? Can I put all 351m parts on the back of it?
Old May 28, 2012 | 05:26 PM
OrFordGuy's Avatar
OrFordGuy
im assuming that your in the 7.5 -460 forum that thats what you have... the 351 bellhousing will fit..he motor plate (the one betwwen the motor and flywheel) will fit but needs to be trimmed around the crank... the flywheel and clutch i use is from a 75/76 390 (diagphram stlye)as there nuetral balance. be sure to get a roller crank pilot shaft bearing for a 460 though.. the bearing for the 390 fits but in the wrong place...learned that the hard way it cost me a bellhousing..the 351 starter should work solong as your not running a monster compresion big block..
Old May 28, 2012 | 11:36 PM
JB78f150's Avatar
JB78f150
Well I took all the measurements and the 390 bearing worked just fine. Still had about a quarter inch clearance.
Old Jun 1, 2012 | 01:05 AM
OrFordGuy's Avatar
OrFordGuy
when i did it the 390 bearing sat in the outer most bearing step in the crank... the pilot shaft slid in but when i tightened it down the clutch spline teeth hit the bearing when it snapped the bell housing... thats what i get for usingan impact gun...glad your having better luck
Old Jun 1, 2012 | 01:14 AM
JB78f150's Avatar
JB78f150
Once I got the engine at the right angle everything slid right in. We started by sliding the trans back but could never get it to seat. Finally we said screw it and pulled the front clip and motor. Only takes like twenty minutes if you have done it before. By tilting the front of the motor up it made everything slide together.
Old Jun 1, 2012 | 01:20 AM
OrFordGuy's Avatar
OrFordGuy
waasn't the problem for us once we pulled it to replace the bell housing we found the teeth marks in the pilot bushing....glad you didn.t have the same issue bellhousings can be expensivbe...
Suzukiboy2012
Apr 25, 2012 02:24 PM
JB78f150
Mar 25, 2012 07:49 PM
rathighboy
Oct 19, 2008 07:29 PM
rk40977
32
Oct 19, 2003 10:13 PM
fastford456
Feb 8, 2003 10:15 AM
