I recently bought a 460 long block on ebay. It arrived pretty much in great shape including the harmonic balancer shipped loose but no external balance weight. The PO says it did not have one. My believe that all '88 Fuel Injected motors were externally balanced. What do you think?
The casting number is consistent with the external balancer. Could a pre '78 crank be installed in this block? If so how can I verify the crank vintage of the crank?
the early cranks will not fit in the late model blocks without clearencing, you can put the late model external balanced cranks in early blocks but not vice versa.
