Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
FTE Meet
Old Dec 9, 2006 | 11:07 PM
  #46
66gpw's Avatar
66gpw
This got me thinking about the 46 panel out near here and Morris mentioning of a 4x4 frame. We could drop the 46 panel on that 4x4 frame and use the panel sides to paint our Man/ sask. Chapter logo on it. That would be great.
Old Dec 9, 2006 | 11:28 PM
  #47
Fomoko1's Avatar
Fomoko1
Not a bad idea but it`s a major over taking, the 51 would be quicker and easier to start with for the club`s first project.
Old Dec 10, 2006 | 12:12 AM
  #48
Snowking's Avatar
Snowking
Why stop at one or two, lets not get ahead of ourselves though, but that is the point of a club, Remeber these may just be "flagships" but just think how many we could start doing if they are going good.
Old Dec 10, 2006 | 09:45 AM
  #49
51dueller's Avatar
51dueller
I could put that 46 on that 4x4 frame in a jiffy as I'm a black belt in frame swaps.
Old Dec 10, 2006 | 10:40 AM
  #50
Snowking's Avatar
Snowking
It's fine if the 46 panel seems like a better project I got all the parts I nedd for my grain truck I can fix her up good and still put a banner on it for cruise weekend.
Old Dec 10, 2006 | 01:37 PM
  #51
preppypyro's Avatar
preppypyro
Hmm a 46 panel would be really cool too.
Old Dec 10, 2006 | 03:54 PM
  #52
Fomoko1's Avatar
Fomoko1
Nathan, think you can do the panel frame swap in 90 days with your busy schedule?
If you can I`m willing to donate the 4X4 frame, we`d have to find out the cost of the panel.
Old Dec 10, 2006 | 04:19 PM
  #53
Snowking's Avatar
Snowking
If I emeber right your transfer case was cracked. I have one that might fit I don't know if it was from Ford Chevy or Dodge but the vehichle had Dana axles.
Old Dec 10, 2006 | 04:29 PM
  #54
Fomoko1's Avatar
Fomoko1
Your right, I forgot about that. Since I have no plans for it I never did check around for a case. Possibly this one could be welded up but I`m not sure about that.
Old Dec 10, 2006 | 04:31 PM
  #55
Snowking's Avatar
Snowking
Mine is free, don't know if it'll bolt up though.
Old Dec 10, 2006 | 07:37 PM
  #56
51dueller's Avatar
51dueller
I could get it done. I did mine in 2 months and I could do it faster since I know what to do now. As long as there is plenty of good steel around. There will be costs though like a shortened rear driveshaft as it will be going from a 131" to 114", a radiator for the 360 and a clutch and pedal assembly from a '67-72 truck (I guess I could use the one out of the towtruck). The brakes will probably take some work as they haven't been used in awhile.
Only a Ford transfercase will bolt on, you might be able to use some parts from other ones. I think we could leave it alone for now as it will be fine if it's out of gear.
Be a little tricky to lift the panel body of the original frame with the bobcat. I would need both frames side by side in Fomoko's shop to make sure everything will fit correctly. The 46 will also sit higher than my 51 because I don't have the frame length to cut out the hump and it will require less sheetmetal modifications. Plus it will fit the big 31" tires better.
I can also use Fomoko's digital camera to keep track of progress and make another tech article.
Old Dec 10, 2006 | 07:59 PM
  #57
Snowking's Avatar
Snowking
I think I'm useless here I've tried and failed a frame swap B4 so don't expect any knowledge from this side, restoration is my thing.
Old Dec 10, 2006 | 08:43 PM
  #58
Fomoko1's Avatar
Fomoko1
We need to find out the cost of the panel, looks like the rest may fall into place. I have sent a pm to Glen to see what/how soon he can find out the price and condition.
It shouldn`t be much of a problem lifting the panel off with the Bobcat, two slings and some personal to balance it will work fine.
Snowking, I hope you do stay on board.
This may not even work out till the price/condtition is known on the panel. If it`s a go then it will take all the help that can be found, it will be a big project.
Old Dec 10, 2006 | 08:47 PM
  #59
Dustin1690's Avatar
Dustin1690
Sounds like a really cool idea another one of the tech articles would be neat to see once again
Old Dec 10, 2006 | 09:49 PM
  #60
Snowking's Avatar
Snowking
I want to help but probably useless.
