alt guage
Old Nov 14, 2006 | 08:44 AM
bohiaa's Avatar
bohiaa
alt guage
Hello everyone:
today my 93 f150 didn't crank for work, I knew I needed a new battery but you kno how it is. I'll get around to it.
anyway the guage on the alt. seems to stay to the plus side and I was wondering if anyine knew how it works?
is this the power comming fron the altnator? of is this the power going to the battery, or what. I'm confused
also when my drivers side window is up and I press the button "power windows"
the guage takes a hell of a plundge towards the sown side, but the passenger window does not do this.
thanks for sheding any light on this for me
Old Nov 14, 2006 | 10:29 PM
Old_Paint's Avatar
Old_Paint
The gauge is a voltage gauge, and should read slightly to the right of center, center being 13.8 volts. When the engine is running, battery voltage should be around 14.0 - 14.2 volts.
If you're seeing a big plunge in the gauge, it means you've got some binding in the window and you're probably going to be putting a window motor in soon. Heavier current draw will drop the battery voltage, particularly at idle, until the voltage regulator can compensate. The voltage regulator isn't real fast, not to mention the reactance of the alternator takes a bit to push current through and won't happen instantaneously. The passenger side window doesn't get used nearly as much as the driver's side. It'll last 4 times as long as the drivers side, or seize up from lack of use.
choptop49ford
21
Nov 22, 2012 08:24 AM
Wisebuck
Sep 8, 2011 01:53 AM
chjg03
1997 - 2003 F150
Jun 6, 2011 01:03 PM
sparkyrhett
May 7, 2007 02:21 PM
mgundry
Electrical Systems/Wiring
May 31, 2004 11:46 AM
