Heater Hose Hook Up
Old Nov 13, 2006 | 11:27 PM
OneFine69's Avatar
OneFine69
Question Heater Hose Hook Up
Hey Guys-
I just installed a rebuilt 390 in my 1969 F-250. I cant remember which hose goes where though. On the fire wall, if you're standing infront on the truck looking at it, there are two pipes sticking out- same length. Which side gets the hose with the heater control on it? Which hose connects to the water pump? My intake manifold has a "T" coming out of it, so where do those two hoses go? I appreciate the help- I want to hear this bad boy start up!
-Tristin
Old Nov 13, 2006 | 11:45 PM
Fritolay's Avatar
Fritolay
th hose with the control goes to the pump the other one goes to the intake. or at least that is how mine is routed the t on the intake the other hose should have run to a plate under the carb. if you removed that plate change the t fitting out for a 90.
Old Nov 14, 2006 | 06:10 AM
jowilker's Avatar
jowilker
Tristin, I don't believe there is any directional requirements for the core, so basically it will work either way. I recommend flushing the core with a garden hose in both directions before hooking it back up.
John
Old Nov 14, 2006 | 03:02 PM
OneFine69's Avatar
OneFine69
Appreciate it guys- I just didnt want to mess up something so simple.
-Tristin
Old Nov 18, 2006 | 11:27 AM
orich's Avatar
orich
The water pump heater hose nipple sucks in, engine is turing clockwise. And the hose nipple T or Y what ever you want to call it.. pushes the flow out and through carb base plate heating it. and then too a T in the heater hose returning to the water pump. my 2cents
orich
Old Nov 18, 2006 | 03:28 PM
jowilker's Avatar
jowilker
orich
Are you sure about that??
Why would a pump be sucking from the heater core line?
John
Old Nov 19, 2006 | 09:07 AM
68'F-250CS's Avatar
68'F-250CS
the pressure line comes from just behind the thermostat housing so the water pump has to be sucking from the heater core. just my two cents
Old Mar 4, 2008 | 08:10 AM
mikey92665's Avatar
mikey92665
have new bored and built 350-4bolt.400 trans. 4 my 68 truck.do i put this in or do i rebuild 302 3speed? building a street truck'need opinions!
Old Mar 4, 2008 | 10:57 AM
jowilker's Avatar
jowilker
as long as your 68 is a chevy, by all means install it. If it is not, you are on the wrong site for chevy questions.
John
Old Mar 4, 2008 | 11:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Fresh air heater: The inline heater water valve (C3UZ-18495-A) is spliced into the input heater hose, not the return line.
Ppl install the water valve in error into the return line and then wonder why the heater doesn't get hot enough.
Is the water valve missing or rusted out?
It's still available from Ford, and autoparts stores (Motorcraft YG-133).
Old Mar 4, 2008 | 01:25 PM
mikey92665's Avatar
mikey92665
68 ford, look at my profile.changed my mind to a 302 thanks.
diesel 04 X
Dec 1, 2024 10:24 PM
84StraightSix
1997 - 2003 F150
Jun 9, 2014 02:46 PM
wolfpackfan94
Nov 21, 2013 07:15 PM
MikeD1980
Jan 23, 2011 11:10 AM
Mohave
Modular V10 (6.8l)
Sep 11, 2009 11:07 AM
