72 F600 brake lights
Hi all. I have a 72 F600 dump truck which has no brake lights. The turn signals and emergancy flashers work, and I have power at the brake pedal switch. I am needing ideas on what to check next. I have had the steering wheel off and checked the turn signal switch, but did'nt really know what I was looking for as far as what wire should have juice. If anyone would have a wiring diagram or could tell me what color wires are in the system it would be appreciated.
Thanks
Thanks
Originally Posted by jetfixer
Hi all. I have a 72 F600 dump truck which has no brake lights. The turn signals and emergancy flashers work, and I have power at the brake pedal switch. I am needing ideas on what to check next. I have had the steering wheel off and checked the turn signal switch, but did'nt really know what I was looking for as far as what wire should have juice. If anyone would have a wiring diagram or could tell me what color wires are in the system it would be appreciated.Thanks
D1TZ-13480-A .. Stoplight Switch (Motorcraft SW-1027)
Fits: 1968/72 F500/750 with hydraulic brakes.
You said earlier that your HAZ was working, front & back? or just the front? Does the turn signal work in back?
If not in back, pull the lens and housings and clean up the grounds. Then use a test light and see if your getting the power back to your tail lights. Look at your lightbulb and see if the contacts are clean and good.
Yes there is a plug at the top of the column. After you had mentioned that I went and checked for power with the brake pedal pushed. I am only getting about 3 volts at the top of the plug. I checked continuity from the brake switch to the plug, that checked out good. I then checked volts at the power wire to the brake switch and for some reason I am only getting 3 volts there also. I would assume I should have 12 volts there, so I guess I have a problem fro the fuse box to the brake switch. Thanks for your input.
I have a feeling that's what the problem is. I redid the connections at the brake switch, but was still not getting a full 12 volts. I ran a jumper from the fuse box direct to the brake switch and now I have brake lights so I can get back on the road. When I have more time I'll check out the fuse connections. Thanks to everyone for your input.
Lusche
08-08-2017 07:23 PM
waverous
10-10-2016 10:10 AM
Kitty Chandler Carr
10-02-2016 12:18 PM
Francisco Garcia
08-27-2016 04:20 AM
