boost gauge
Old Nov 15, 2006 | 07:45 AM
ford4lifer's Avatar
ford4lifer
Originally Posted by raptor131
i tapped intake elbow, that way i know exactly what amount is going into intake manifold very simple to remove drill and tap.very accurate without any needle flutter like some have reported from t-ing other sources
Did you remove the elbow or remove the hose and put a vaccum hose inside while drilling and tapping. Also playing with the idea of getting the aftermarket elbow, I assume most of you have seen these any thoughts on them? The one I'm looking at has a nipple for a boost gauge hook-up. Around $179 I think.
Old Nov 15, 2006 | 07:57 AM
dynarider1995's Avatar
dynarider1995
My Boost gauge is on the map sensor pressure line. I teed off this line. But I do get the fluttering boost pressure reading. I’m thinking of moving the boost pick up line to the intake manifold. The fluttering is annoying.
Old Nov 15, 2006 | 08:21 AM
Bear Hunter's Avatar
Bear Hunter
Yep the intake elbow is the best place for the boost tube...as mentioned earlier, this location will give you smooth readings throughout the range. Tapping into the MAP line will give you boost gauge flutter at higher PSI's.
After you remove the stocker you can drill it with a Type "R" (.339) drill bit or a 21/64" drill bit. Tap with a 1/8 NPT tap. I recommend using an elbow fitting to prevent the tube from interfering with the oil or fuel filter caps during routine maintenance.
...or you could purchase an Accufabracing Power Air Inlet...which comes pre-drilled and tapped
Old Nov 15, 2006 | 08:26 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Like this one . . .
There is a mounting hole on the Accufab Intake elbow, which might be the one you are referring to. I would have used that but I put the elbow on way after I had the guages in.
You can see the mounting hole in the back ground on the polish elbow. . .
Put the Pyro probe on the exhaust . . .
Old Nov 15, 2006 | 07:21 PM
raptor131's Avatar
raptor131
yes i removed it to tap it. it's only four bolts and the clamp. comes off in 2min. i just covered the neoprene hose with wire loom to protect it. plus it looks a little more oem. but the best way would be to buy the one with the nipple pre-installed. . but it looks nice chrome. $179 just for the elbow is not worth it to me, i would justify that money towards exhaust though
Old Nov 16, 2006 | 08:57 AM
Lonewolftx's Avatar
Lonewolftx
Wink More to it . . .
It is a racing application design not a pretty piece. Also it is not chrome, it is polished. It is all a part of a master plan for engine improvement!!!!
pip-clark
16
Sep 7, 2007 09:44 PM
blksiryder
16
Sep 1, 2007 03:49 PM
FORDSDOWNER
Aug 27, 2007 03:17 AM
Turf Truck
Feb 6, 2004 11:15 AM
myst
Jan 14, 2002 10:48 AM
