boost gauge
Old Nov 13, 2006 | 04:33 PM
ford4lifer's Avatar
ford4lifer
boost gauge
where is the correct or best place to mount the nipple for the boost gauge?
Old Nov 13, 2006 | 05:00 PM
BowTieHatr's Avatar
BowTieHatr
use the map sensor nipple. just unscrew it and make a hard line or just "tee" into it.
Old Nov 13, 2006 | 05:50 PM
ford4lifer's Avatar
ford4lifer
pretend I'm stupid where is the map nipple?
Old Nov 13, 2006 | 06:00 PM
BowTieHatr's Avatar
BowTieHatr
look right behind the oil fill cap, small hose attached to a nipple on the intake. your gonna have two nipples one goes to the coolant jug and the other map sensor.
Old Nov 13, 2006 | 06:01 PM
Jocaren's Avatar
Jocaren
I like that
Old Nov 13, 2006 | 06:02 PM
ford4lifer's Avatar
ford4lifer
ok thanks got it... thats the best place to put it
Old Nov 13, 2006 | 06:05 PM
BowTieHatr's Avatar
BowTieHatr
thats where the computer take a boost measurement! just make sure you use a tee so the map sensor can still sense boost.
Old Nov 13, 2006 | 06:44 PM
raptor131's Avatar
raptor131
l your gonna have two nipples r.
are we taliking about trucks here?
Old Nov 14, 2006 | 05:51 AM
BowTieHatr's Avatar
BowTieHatr
mmmmm.......
Old Nov 14, 2006 | 10:44 AM
Lonewolftx's Avatar
Lonewolftx
Talking Hummm . . . .
I checked on my '06 and there is a nipple for the coolant bottle but the other Hole only has a bolt extending for the alt wiring harness to hook on to. Also was to the far right of the Oil Filler cap flooking into the engine. Not an option for later years from '05 on eh?
By the way have you ever teed up a nipple? I've seen some that are tall enough when the weather turns cold . . .
Old Nov 14, 2006 | 03:48 PM
gryf250's Avatar
gryf250
was wondering if we talking about trucks, lol!
Old Nov 14, 2006 | 07:01 PM
npccpartsman's Avatar
npccpartsman
An alternative place is to tap into the throttle body elbow. Some gauges don't like the map sensor line (for whatever stupid reason--fluttering or something like that). Either is a good place, just depends on what tools or abilities you have at hand.
Old Nov 14, 2006 | 08:21 PM
mrxlh's Avatar
mrxlh
You can always use a needle valve or a baffle to control this. This is a common problem with gauges (pressure) on gas compression equipment, the inhearent pulsation.
Old Nov 14, 2006 | 09:39 PM
BowTieHatr's Avatar
BowTieHatr
well there must be something speacial (and it not water filled) about the gauge i use at work because i have never seen a flucuation
Old Nov 15, 2006 | 07:23 AM
raptor131's Avatar
raptor131
i tapped intake elbow, that way i know exactly what amount is going into intake manifold very simple to remove drill and tap.very accurate without any needle flutter like some have reported from t-ing other sources
