Sponsored by: Auxito
Power windows and locks install
Old Nov 12, 2006 | 01:00 PM
Munky's Avatar
Munky
I currently have manual windows and locks in my 2000 F-150 Ext cab 4.6L. I would like to get power windows and locks installed. How hard would this be to get done and does anyone know of a good place that can do it (such as a Ziebart, etc.)?
Old Nov 12, 2006 | 08:59 PM
Racerguy's Avatar
Racerguy
Anyone here installed power windows or locks?
Old Nov 13, 2006 | 06:55 AM
DoofusOfTheDay's Avatar
DoofusOfTheDay
No, but I've seen Bruce Bonebrake do it on weekend mechanic. Didn't look very difficult. If you are okay with taking off the door panel and are fairly handy, seems pretty straight forward. I'd do it, and I'm not ASE certified! I actually put in my own remote starter, which also controls door locks. Which is pretty easy also.
http://www.diynetwork.com/diy/shows_..._26866,00.html
Is that his real last name, Bonebrake? That's a cool last name if it is.
Old Nov 13, 2006 | 07:19 AM
ncranchero's Avatar
ncranchero
I would suspect that the wiring is already in the main harness, it was on my '94. Remove the right kick panel and verify that there is a "group" of plugs on a bracket there, half plugs I should say. (There will be the same thing behind the left kick panel. Follow the speaker wiring from your door, theyll all be right together) If so just gig the window regulators and locks from a damaged door at your local salvage yard, bolt/rivet them in and plug them up. There may be a minimum of wiring connection needed at the fuse panel and/or relay center. Get a good FORD wiring diagram and go to it. This is a photo of the 91 donor left kick panel wiring that my 94 power doors came from.
Old Nov 13, 2006 | 05:56 PM
Munky's Avatar
Munky
Doesn't look to difficult. Time to print the directions off and save them and have a spring project. Thanks guys!
jenkinsj
Electrical Systems/Wiring
Mar 10, 2013 08:14 PM
firefrostn1
Engine Swaps
Sep 6, 2006 11:06 AM
sleepysal
Aftermarket Products
Jan 12, 2005 09:18 AM
3-0joe
1983 - 2012 Ranger & B-Series
16
Jun 5, 2004 03:38 PM
