Sponsored by: Auxito
2002 cruise control inop
Old Nov 12, 2006 | 11:49 AM
xclint's Avatar
xclint
cruise stopped working - any trouble shooting info would be appreciated
thanks
Old Nov 12, 2006 | 12:43 PM
BigsockMouse's Avatar
BigsockMouse
Check the fuse and the brake light switch on the master cylinder. I had the same problem and it turned out to be a bad brake light switch.
Old Nov 12, 2006 | 03:19 PM
kharmaguru's Avatar
kharmaguru
Just curious if your truck was part of the recall for speed control switch?
https://www.ford-trucks.com/recalls/...y-2002/t-59804
Old Nov 12, 2006 | 08:58 PM
Racerguy's Avatar
Racerguy
Welcome to the forum xclint
Old Nov 13, 2006 | 04:38 PM
BillyBob69's Avatar
BillyBob69
Mine was part of the recall so his should be.
Take it to a dealer and have them do the recall fix. Could be that the harness is about to fry. The main part of the recall was that the CC would quit working then it would catch fire even with the truck parked and off. Look at the plug on the front of your brake fluid resevoir and unplug it until you get it to the dealer for the recall fix. That could possibly cure your problem altogether. If not, then I would check fuses and connections.
Old Nov 13, 2006 | 09:52 PM
cbb's Avatar
cbb
Inop Cruise
Run, dont walk to the dealer. This should be covered in the recall. In the meantime, unplug the connector on the top of the master cyl. This is the infamous switch that has caused fires, even with it turned off and parked for a few hours.
Old Jul 22, 2007 | 10:44 AM
xclint's Avatar
xclint
been a while on this post
thanks to all for info......
-- dealer replaced harness per recall - didn't fix it - brake lights work fine but will check setting / switch - don't use it much due to driving style -
Old Jul 23, 2007 | 02:50 AM
LxMan1's Avatar
LxMan1
Could be a bad clock spring in the steering column.
Old Jul 23, 2007 | 06:30 AM
projectSHO89's Avatar
projectSHO89
Well, it could be a lot of things....
Bad SCDS switch/blown fuse link, clockspring, brake light switch, and the whole rest of the thing.
IIRC, the 2002 has a diagnostic built in.
Steve
Old Jul 23, 2007 | 08:34 AM
xclint's Avatar
xclint
2002 f150 6 cyl - no code (if that's the definition of diagnostics)
where would the - SCDS switch/blown fuse link - be located ? scds acrynm for ?
assume (?) that if b-lights working switch is assumed good
thanks -
Old Jul 23, 2007 | 11:23 AM
skilife17's Avatar
skilife17
Like was stated it could be many things. I had the recall taken care of on my 97 F150 last year and about a 1.5 months ago my cruise quit working. I checked the obvious the fuse under the dash, the fuse in the harness that was installed. I then looked at the switch on the master cylinder and it was wet. I went ahead and replaced it and my cruise has worked fine ever since.
fordiesel69
2004 - 2008 F150
Nov 16, 2017 08:40 AM
das_16
Ford Truck Parts for Sale
Jun 17, 2017 10:42 PM
screwxtr
Mar 26, 2017 05:19 PM
Mitchell_Texas
Aug 22, 2015 07:14 AM
79str8six
Feb 4, 2012 01:02 PM
