Adding cruise control.......
Old Dec 19, 2016 | 09:46 AM
fordiesel69's Avatar
fordiesel69
Can someone tell me how to add factory cruise to my 2005?
I am hoping it is as simple as swapping the steering wheel and having dealer turn on cruise in the PCM.
Old Dec 19, 2016 | 10:36 AM
jr105's Avatar
jr105
You don't have to change the whole steering wheel, just remove the blank and add the switches. Then have the PCM reprogrammed. There are Youtube videos on how to do this. I was going to do this when I had an '04 but never got around to it.
Old Feb 7, 2017 | 01:45 PM
baitmaster's Avatar
baitmaster
My 05 also has a switch on brake pedal, aside of the brake light switch, to turn cruise off when you have to brake.
Old Nov 16, 2017 | 08:40 AM
fordiesel69
Ok so to update this thread, I just got done with this and can confirm for anyone else, the 2004 new body, thru 2008 are for sure wired. It is as simple as popping in the switches where the blank covers were, and having dealer reflash the PCM with cruise enabled. Thanks ford for making this simple!
2004 Heritage (older round body) is NOT completely wired. The steering column, and cruise servo wires are intact, but the master cylinder switch, and fused circuit in fuse panel is not present. Screw you ford!!!!
GuitarJesus
Jun 26, 2012 08:54 AM
BigE2000
Aug 21, 2011 07:14 PM
carrfamilynj
Dec 6, 2006 12:32 PM
88svt
Modular V10 (6.8l)
Jun 17, 2005 10:26 AM
nwajetmech
1997 - 2003 F150
Mar 13, 2004 07:16 PM
