Stepside? Fleetside? Can't Decide!
Old Oct 10, 2007 | 10:23 PM
  #76
AXracer's Avatar
AXracer
new genuine GM 88-91 GMC Right and left tailgate latches 22.03 each from www.gmpartsdirect.com
Old Oct 11, 2007 | 11:07 AM
  #77
ferguson777's Avatar
ferguson777
Ax,
It's the tail gate handle assy that I need (if I stay manual) as mine is all rusted up. the rods from each latch assy join onto the handle assy in the center of the tailgate.
That website doesn't list that part. I'll be stopping in at my GM dealer and my favourite parts store sometime in the next few days.
It's interesting though that for the first time since the mid-70s, the Cdn $ is worth slighty more than the US $, so except for freight, etc, it would actually be cheaper to buy it in the US......
Thanks though.
Old Oct 11, 2007 | 11:19 AM
  #78
AXracer's Avatar
AXracer
Originally Posted by ferguson777
Ax,
Thanks though.
it actually does if you drill down far enough, exterior handle $22.71, handle bezel $9.30. If you are going solenoid, you just need to attach it to the latch rods.
Old Oct 11, 2007 | 12:26 PM
  #79
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Danger – Dark Side project discussion. Light Siders be warned.
As mentioned in a couple of places recently in this forum, I’ve decided to go the psudo-fleetside or combination route for the bed on my 54. That is, use a fleetside box in a step side manner. In the belief /knowledge that others are doing the same, I’ve started this thread to enable anyone that’s interested to offer advise or ask questions. (I’ve also started a gallery for this project as well)
After looking at Rangers, S10s and various other beds, I decided upon using a mid- 90s ch*vy box from a Silverado or Sierra. While all specific alternatives mentioned here seem to fit the critical requirements –
- center of wheel well approx. 40 inches from front of box.
- floor of bed about 19 inches from bed top
- side profile is similar to 54 cab profile
the full sized Chevy short box has a couple more pluses that the others don’t. I found the lines of the S10 box very pleasing, but the design or feature detail near the bottom (the lower qtr panel – in front of and behind the wheel well) is raised or protrudes out from the body. This is pretty much common on almost all truck beds EXCEPT the Silverado/Sierra from the mid-90s. On this bed, the design is recessed into the side wall of the bed. This will make it very simple to fill it and therefore end up with a smooth outer side wall – matching the side profile of the 54 cab.
Much of this is subjective - a matter of personal taste, so if you disagree with anything I am saying, no problem.
If you grab the short box or the box used on the extended cabs, you’ll have a 6.5 ft box, which is perfect for this project.
BTW – I looked at the semi-stepside bed that ch*vy used in the mid 90s and while I feel it looks beautiful on a 55-57 Ch*vy pick up, I don’t feel the fenders work on a 53-56 Ford……
My measurements tell me that to have approx. 7 inches of stock fender on each side, I need to cut the box down to a maximum width of 60 inches. BTW – this will give me a floor width on the inside of the bed of about 48 inches – within an inch of the stock bed inside width.
At this point (the morning of 11/12/06) the box has been cut down and welded back together. We’re bringing it home today to (hopefully) drop in place.
After that, I’ll play around with it at home for a month or two;
- fitting patches for the stake pockets
- fitting patches for those feature/detail recesses discussed above
- fitting a patch in place of the gas filler door
- trimming back the stock wheel well lip
- replacing the wheel tubs and patching the floor
- deciding whether to fit smooth inner side walls
- figuring how to finish off the inner edges to accept a wood floor
Cutting the box down was fairly easy. Only took us about 4 hours. All that other stuff including scribing the stock fenders to be cut, will take some time though…….
Ach du lieber!
Can't decide whether to have a step-side or fleetside?
Here's a bit of help = both are Chevrolet terms.
Fords are Flaresides (not stepsides) and Stylesides (not fleetsides).
Old Oct 11, 2007 | 12:29 PM
  #80
AXracer's Avatar
AXracer
But since he used a GM bed, fleetside would be proper...
Welcome back ND, you've been missed!
Old Oct 11, 2007 | 12:47 PM
  #81
NumberDummy
Computer failure 8/29, it was sent to HP THREE times before problem could be solved. The problem was sooo simple = it would not turn on! It was not the power cord. HP replaced: the motherboard and the on/off switch..what I told them was defective in the first place. When one calls HP's 800 help number...the call is answered...R U ready for this...in INDIA! The whole sorry affair was a Royal PITA!!
A word to the wise...laptops can only be repaired under warranty by the original maker. Geek Squad, Firedog etc. will charge you a $100.00 fee to diagnose, but once the p/c is opened, the original manufacturers warranty is void. These outfits can diagnose, but can't repair them. Go figure.
Old Oct 11, 2007 | 02:14 PM
  #82
WALFORD'S 56's Avatar
WALFORD'S 56
I thought you took a trip to buy some antique guns/parts/signs/license plates/trucks--or misc.......welcome back N.D........Bill OH--YEA---ksmith sold his wrecker truck!!!And after all the advice you gave him---LOL
Old Oct 11, 2007 | 05:28 PM
  #83
ferguson777
Ax,
My local Benson's AutoPartsExtra (the best auto parts store in the Ottawa area) has the tailgate handle/mechanism assembly for $28.00 cdn.
Looking at the room in the tailgate and all, I've decided to go with the "stock" GMC handle assy albeit mounted from the inside of the bed. It'll be easier, cheaper and simpler to repair in future.
(Gotta avoid the tendancy to go for trick just for the sake of trick)
Later,
Old Oct 11, 2007 | 05:55 PM
  #84
AXracer's Avatar
AXracer
but a solenoid tailgate latch would be sooo cool! just think some greasy pawed rug monster comes up to the back of your truck at a show and starts writing his name in dog poo with a broken stick on your tailgate... a push of the button from 10 feet away and the tailgate suddenly releases on the little darling's head driving him 6" into the pavement. As the unattentive parents come running over to see why he's screaming you can wander over and say "I don't know how that happened, never did it before..."
Old Oct 11, 2007 | 06:10 PM
  #85
ferguson777
Ax,
Well that is definitely something I would do....
76 MA Bronco
1966 - 1977 Early Broncos
16
Jun 4, 2007 08:00 PM
69crewcab
Jan 7, 2006 05:06 PM
the law
32
Jan 3, 2003 06:52 AM
TheNomad
Jul 25, 2002 09:19 PM
Bill_Beyer
21
Dec 3, 2001 10:46 AM
