Engine swap
Old Nov 13, 2006 | 07:58 AM
AMDCAMARO's Avatar
AMDCAMARO
So just leave the KS plugged in and hanging somehwere? or do u not even have the sensor plugged in?
Old Nov 13, 2006 | 08:35 AM
Scndsin's Avatar
Scndsin
The article shows it to be screwed into a boss on the "upper bellhousing bulkhead". I would guess that it is an intregal casting to all 302 blocks, regardless of application. But whether or not it would have threads cut is a question. The 91 HO they used as a donor had it.
Old Nov 13, 2006 | 02:00 PM
nighthawk285's Avatar
nighthawk285
i dont even have the sensor plugged in, i have taped off the end to keep crap from getting in there, and its taped to the other wires
Old Nov 13, 2006 | 07:44 PM
triple150's Avatar
triple150
The knock sensor will not affect how this engine runs, I guess the computer will adapt?
Firing order will stay the same as the truck diagram states 1-3-7-2-6-5-4-8
What other diferences may I come across swapping the 1988 mustang HO
Old Nov 13, 2006 | 08:00 PM
redlightning's Avatar
redlightning
https://www.ford-trucks.com/forums/5...ighlight=knock
I put an 82 engine in my 91.I posted the question on this board(knock senor) and got the above advice.
I just drilled and taped a hole the for the knock sensor as suggested.The metal was easy to drill and tap.I did put a couple of washers under it.The trucks running great.
Old Nov 13, 2006 | 08:18 PM
triple150's Avatar
triple150
redlightning,
Your thread stated changing the front cover, was this the timing chain cover because of a mechanical fuel pump?
Old Nov 13, 2006 | 09:21 PM
redlightning
I took it down to a long block and installed a new timing chain and gasket kit.I swapped the front cover and everything else so I wouldn,t have any problems with the power steering,a/c,etc.
http://i77.photobucket.com/albums/j4...91truck302.jpg
Old Nov 14, 2006 | 01:23 PM
AMDCAMARO's Avatar
AMDCAMARO
put both vehicles on the CSK website and check all the parts, cam, oil pan, timing set, water pump, harmonic balancer.
Only thing thats different on my 1991 crown vic 302 to my 92 F-150 is the water pump.
On your 88 triple, u may not have the roller cam, im not sure.
So what I am gathering is the swap will work, I may have to drill and tap my own KS boss. IF I decide not to drill and tap, or the tap breaks (icky) i will be taping off the sensor and taping it to the wiring harness, out of the way.
Scndsin, is there anything else you see that im missing? I cant find that magazine anywhere, not even the Library. The book store by me has the one that says display until febuary allready.
Old Nov 14, 2006 | 07:09 PM
triple150's Avatar
triple150
I will have the roller cam as long as the block is from a stang. Otherwise will this pose a problem with the ECU?
I know I am starting to sound like a broken record, but just trying to learn more about doing this swap smoothly?
Cheers!
Old Nov 14, 2006 | 08:12 PM
nighthawk285
no, because the roller cam should have the same lobe separation (114 degrees) as the original one, since both of them were computer-controlled, so there shouldnt be a problem there
newstylecustoms
Jun 13, 2011 05:45 PM
mikeatcaryville
1997 - 2003 F150
Nov 16, 2010 03:13 PM
quickstang
Engine Swaps
Aug 13, 2010 11:21 AM
davidtgreen150
21
Mar 14, 2010 05:08 AM
Epd444
1978 - 1996 Big Bronco
Feb 7, 2008 04:48 PM
