Sponsored by: Real Truck
Help please i'm Tired.
Old Nov 10, 2006 | 12:12 PM
exiled's Avatar
exiled
Pune intended. me and my buddy disagree about a tire's hight. I say that a 285/75r16 has the same hight of a 265/75r16 but just wider. He says that the 265 is taller therfore changing my reargear ratio on final drive.
Old Nov 10, 2006 | 12:17 PM
vloney's Avatar
vloney
its 285 millimeters tall---the height is 75% of the width---16 inch rim
Old Nov 10, 2006 | 12:19 PM
Pocket's Avatar
Pocket
You are both wrong. The 285/75r16 is the taller and wider tire. First metric number is the tread width, second number is the sidewall height in relation to the width. Third is of course rim size.
On Edit: Dang, vloney beat me to it.
Old Nov 10, 2006 | 12:30 PM
exiled's Avatar
exiled
vloney, dont you mean that its 285mms wide?
so i guess my buddy was right i forgot the part about the 75 being a percentage of the width in hight.
Old Nov 10, 2006 | 12:40 PM
vloney's Avatar
vloney
nope, measure from the wheel to the top of the tire.
Old Nov 10, 2006 | 12:50 PM
Pocket's Avatar
Pocket
Wait a sec vloney, I just reread your post. The first number is the width of the tread, not the height of the sidewall.
Old Nov 10, 2006 | 01:04 PM
Baja Daze's Avatar
Baja Daze
Everything you ever wanted to know about tire designations.
http://www.tirerack.com/tires/tirete....jsp?techid=46
Old Nov 10, 2006 | 01:06 PM
Sockeye Salm's Avatar
Sockeye Salm
Wow!! Now I'm really confused. Walk me through this one step at a time please.
You guys are saying 285 mm wide, that converts to 11.22 inches.
then the sidewall height is 75% of 285 mm which is 213.75 mm or 8.415 inches.
So that means you add sidewall height to 16 inch rim height for a grand total of 24.415 overall tire height?
That can't be right. What am I missing here? ...........
Old Nov 10, 2006 | 01:11 PM
ryaneverk2's Avatar
ryaneverk2
Sockeye, you have to add 8.415 twice as there are two sidewalls. So 16 inches for the rim, 8.415 for the sidewall on the top side of the rim, and 8.415 for the sidewall across the rim on bottom. So looks like 32.83 inches overall height. I think that's how you do it...
Old Nov 10, 2006 | 01:12 PM
Super08's Avatar
Super08
Close. It is the section width, not the actual tread width.
265/75-16
section width 265mm
sidewall 7.8"
radius 15.8"
diameter 31.6"
circumference 99.4"
revs/mile 637
285/75-16
section width 285
sidewall 8.4
radius 16.4
diameter 32.8
circumference 103.1
revs/mile 614
Old Nov 10, 2006 | 01:21 PM
Pocket's Avatar
Pocket
Yeah, I can never remember the term offhand. I use the word tread width, it's close enough for an explaination.
Old Nov 10, 2006 | 01:26 PM
Sockeye Salm
Damn Ryan
Did you just make me feel like a complete idiot or what.
Duh!!!!
Where's the smiley for GET YOUR HEAD OUT OF YOUR ***!!!! I deserve one.
Old Nov 10, 2006 | 02:06 PM
ryaneverk2's Avatar
ryaneverk2
Don't feel bad... I didn't even know how to interpret the 285/75r16 except for the 16 inch rims part until this thread. Just never looked into it. I just saw how you were calculating and saw where you went wrong. I actually wrote this down as a note for how to calculate it in the future. Had no idea that the 75 meant sidewall height as 75% of the first number ("section width").
Old Nov 10, 2006 | 02:36 PM
Excursionator's Avatar
Excursionator
Super08, How did you calculate revs/mile? Mile / circumference?
Old Nov 10, 2006 | 02:42 PM
ryaneverk2's Avatar
ryaneverk2
Yep. Make sure you use the same units (convert the tire circumfrence to feet before you divide).
