Sponsored by: Auxito
Power window
Old Nov 8, 2006 | 03:54 AM
shangopat's Avatar
shangopat
Banned
Power window
Hi,
Is there a way to "grease" the power window ?
When opening drivers side,it really slows down halfway.
Thanks
Pat
Old Nov 8, 2006 | 04:11 AM
DoofusOfTheDay's Avatar
DoofusOfTheDay
Yeah, take off the door panel and go for it. Not sure what year and model you have but, for my 1998 it is pretty easy to take off door panel. Remove the long slender trim piece above edge of door by pulling straight out, and do the same with the little triangular piece above the hinge side of the door panel. Pop out little circle trim piece near handle, then remove the handle by unscrewing the bolt that holds the handle to the door. No need to remove that bolt all the way, just enough so it frees it up from the door. Pull door panel straight up, not out and there you have it. I guess you can remove all the wiring connections if you don't have any helpers, but I had my 10 year old just kind of hold the door panel away from the door as I poked in there with grease to hit the tracks and the X-Spot where the 2 pieces that slide along the tracks come together.
blazinjames
Mar 3, 2017 10:46 PM
redrumybronco
1978 - 1996 Big Bronco
Jul 8, 2004 05:04 PM
Dialtone
Mar 31, 2002 08:33 PM
bulabula
Feb 2, 2002 04:26 AM
Electrical Systems/Wiring
Sep 17, 2001 06:28 PM
