The truck is a 1984 F-250 Diesel 4X4 with a 91 front end. I put new doors on that have power windows and locks, the original truck didn't have the power group. I have the harness connecting the two doors, with what seems to be a power source plug(blue with black dots)and a ground (black with white stripe) The fuse box has a spot for circuit breakers to replace the fuses if power windows and locks are being used. I found one plug upper left behind the console which I was told was the power source for the windows and locks(Blue and black colored wire), after grounding it, still no action from the windows or locks.
[font size="1" color="#FF0000"]LAST EDITED ON 16-Sep-01 AT 07:55 PM (EST)[/font][p]I believe that the only connections on doorlocks are connecting the two switches together, then a ground and power. Use a test light to ensure that your power connection is good. I wired mine up to constant 12 volts.
Thanks for pointing out the obvious, I just didn't bother checking my power source. I am going to go constant power source and skip the fuse box, as it is not set up for the power group.
Thanks again.
