1978 - 1996 Big Bronco
Window scratches
Old Jul 7, 2004 | 09:57 PM
redrumybronco's Avatar
redrumybronco
Window scratches
I have vertical window scratches on the rear window and both the driver and passenger power windows.... I was wondering if this was a common problem and if so if there is a "fix" for this to prevent this from happening.
Old Jul 7, 2004 | 10:34 PM
3broncocrazy's Avatar
3broncocrazy
replace the seals. most of the time the ones on the outside goes first.......as in dry out and start getting hard. I've heard rubbing toothpaste on the glass will help remove some of the small scratches...
good luck
Old Jul 7, 2004 | 11:08 PM
redrumybronco
funny thing that you mention that... well it just so happens thats what I did when I bought the truck about 5 years ago because I noticed that the windows were scratched... replaced both the inner and outer ones BUT the problem continues... I had broken the drivers side window once and had it replaced with a new one soon after I replaced the seals... the new window is also scratched, not so much as the others but still... the rear window seems to be getting worse... all the seals look good and are not dried out or cracked, I clean them regularly. I have some window polishing compound that removes scratches but I want to be sure all my efforts are not in vain before I set on removing the scratches.
Old Jul 8, 2004 | 05:04 PM
BOJOFASO's Avatar
BOJOFASO
bon ami will take out minor scratcheswithout to much work and new rubbers should stop them from reappearing.
ManfredVonRichtofen
Jan 7, 2012 07:28 PM
Mickey J
Jul 13, 2010 09:31 PM
Dutch123
Nov 16, 2004 12:49 AM
phoneman71
Nov 13, 2004 03:44 PM
