Hey guys, having some problems with my explorer, need some info and possible where to find parts.
First, the tranny, i believe its done. Throwing a 4th gear slip code although no parts look warn. Better to buy a replacement or rebuild? Where can I find a good replacement?
Second, speedo. It's jumping around all crazy like, won't show a constant speed which then messes with the cruise control (varies the throttle). Now I replaced the vehicle speed sensor, but is this a wheel speed sensor problem? Should I replace the right rear sensor (is this the one that sends the speed signal)?
