Speed Sensor on a 91 ford explorer?
Old Aug 21, 2004 | 11:39 AM
jason_glisson's Avatar
jason_glisson
Where does this thing go? I looked all around the transmission and I couldn't find it. My book doesn't have it in there. Any ideas? I have done work on my car on just about every part and every place except for the transmission. Can some one tell me where it goes?
Old Aug 21, 2004 | 08:11 PM
jclj2003's Avatar
jclj2003
is it 2x4 or 4x4
Old Aug 23, 2004 | 11:45 AM
mrshorty's Avatar
mrshorty
In either case, it should be at the end of the speedometer cable. Either in the tailshaft of the 2WD transmission or the rear output area on the 4WD transfer case.
Old Aug 23, 2004 | 12:30 PM
jason_glisson
I finally found it and I took the old one out and put the new one in. Speedometer still doesn't work. The yellow gear at the end of the sensor had a place in the middle that looked like it was worn out but it may have been there already. Its has a place on each blade of the gear that scoops in like it has been rounded out. Is it suppose to be like that?
Old Aug 23, 2004 | 01:20 PM
Backin72's Avatar
Backin72
You double posted. I posted this in the other one.
http://24.95.36.96/vss_91_explorer_replacement.html
AndeyHall
Jul 10, 2015 10:30 AM
PO1
Oct 5, 2014 10:38 PM
elvia
Oct 5, 2014 11:17 AM
aggiect01
Mar 17, 2014 11:38 PM
aggiect01
Mar 17, 2014 02:20 PM
