Speed sensor
Old May 30, 2006 | 12:34 AM
Explorer98's Avatar
Explorer98
Speed sensor
My CEL light came on and the code was P0715 - Input/Turbine Speed Sensor Circuit Malfunction. Where is this particular speed sensor located and is it easy to replace? I would appreciate any help I can get with this. I've been trying to find out about this for a couple of weeks but have had no luck.
Thanks much.
Old May 30, 2006 | 08:36 AM
projectSHO89's Avatar
projectSHO89
Assuming a 5R55E, the TSS is internal. Requires removal of tranny and partial disassembly to access. The 4R70W does not have a TSS sensor.
The TSS (Turbine Shaft Sensor) is used to measure the input shaft's speed. It's input is used to schedule shifting and to control EPC pressures for shift feel. With this fault code set, you are likely experiencing harsh or delayed/erratic shifting.
There are diagnostics including simple resistance checks that can be done to see if it is a faulty sensor, a wiring concern, or possibly a faulty PCM that is causing the code.
You will either need a copy of the service manual or will need to refer this to a qualifed shop.
Steve
bcaughhorn
Dec 4, 2010 09:32 PM
HaroldCallahan
1983 - 2012 Ranger & B-Series
Nov 15, 2005 08:47 AM
SDJERSEY
May 16, 2005 02:57 PM
lwpman
Apr 28, 2004 08:41 PM
whiteboyslo
Nov 6, 2001 04:19 PM
