explorer woes
Old Aug 5, 2013 | 05:52 PM
Jeff Tate's Avatar
Jeff Tate
explorer woes
Hi,
I have a 99 Explorer eddie bauer 4.0 4wd. Runs great only 125k. Began having issues with ABS Sensor, Replaced both hubs around November 2012 which had new sensors included *needed them anyways,
abs light came on just two weeks ago 7 and was told to replace the abs/vss sensor on rear axle. ABS Light still on.
Well last week the speedometer, cruise control stopped working all together, as well as Check engine light came on, it shifts fine and demonstrates no other problems, radio randomly *(not often) flakes out but that is it. I went to auto zone and the code reader came up with P0500 they sold me a "Front VSS sensor" that supposedly goes on the transmission and connects to the speedometer cable and other end goes in trans, but I've not been able to find where it actually goes, last night went back to auto zone and they sold me a different part "Vehicle speed sensor trans speed sensor" p/n su2320. I'm at a loss as to where to find that sensor, and before I continue spending $$$ I am wondering if anyone has any feedback or similar issues that have been successfully repaired. Living in Mass - god forbid a sensor light is on, and unable to get it to pass inspection....
Old Aug 5, 2013 | 08:25 PM
oneowner83's Avatar
oneowner83
I could be wrong but it was my understanding the VSS took the place of the speedo cable, it sends the info to the computer.
Old Aug 5, 2013 | 10:09 PM
shorod's Avatar
shorod
On the 1999 Explorer the speedometer signal is sourced from the ABS system. There is neither a VSS on the transmission nor a speedometer cable.
The P0500 does indicate that there was an error in vehicle speed indication and the rear ABS sensor has been a common issue in that generation of Explorer.
-Rod
robles4242
Jun 17, 2008 07:59 PM
Pilgrimjt
Feb 6, 2008 10:13 PM
zcarguy
Jan 23, 2006 04:29 PM
ltdlm58
1983 - 2012 Ranger & B-Series
Sep 21, 2004 10:18 PM
