2000 Explorer code help
Old Apr 8, 2008 | 06:15 PM
mriplaybass's Avatar
mriplaybass
I have had no end of trouble with the engine (4.0 V6 w/automatic) cutting out after starting it, when I take my foot off the accelerator, coasting, or idling. Also, it randomly runs rough at driving speeds, though it never quits altogether when running at normal driving speeds (above 30mph or so). I read the codes, and came up with 2 items. However, I have no idea where the problem is physically located, and which parts to replace, adjust, etc. Here are the codes: PO133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1), and P1131 Lack Of HO2S1 Switches - Lean (Bank 1 Sensor 1). Would either of these problems cause the above problem?
Any ideas folks? Thanks!
Old Apr 9, 2008 | 07:49 PM
vicv's Avatar
vicv
I would check the IAC-Idle Air Control. It controls the amount of air allowed into the intake at idle. It is a common ailment. That might fix the rough idle. Then I'd look at cleaning the MAF and replacing the O2 sensors.
hofec1
2004 - 2008 F150
37
Nov 26, 2020 01:45 PM
thunderbird1986
Oct 21, 2013 07:30 AM
loony2000
1997 - 2003 F150
Sep 9, 2007 09:36 PM
cougar_1987
15
Apr 14, 2007 11:03 AM
BltFordTough
1983 - 2012 Ranger & B-Series
20
Nov 3, 2005 07:18 PM
