Ignition
Old Oct 4, 2002 | 11:44 AM
skeleton's Avatar
skeleton
Ignition
The ignition on my 51 f-1 has three positions..."center" position to insert the key, "left" position, and "right" position.
What are the functions of the positions?
Am I correct to assume "right" position is for starting and "left" position is for accessories?
Would I also be correct to assume "right" position will also work the accessories?
Finally, I would imagine I have something wired incorrectly if the heater fan will work when the key is not even in the ignition.
Thanks.
Old Oct 4, 2002 | 02:09 PM
barry's Avatar
barry
Ignition
Yes, the positions on the switch are as you described. And your accessories will work on either position. You must have your heater hooked up to a hot source of power( live all the time). If you have a wiring diagram of the 51 series, I'd check it again. Your harness should have a wire right off the switch to feed power over to the heater.
Old Oct 4, 2002 | 05:00 PM
darkhorse54's Avatar
darkhorse54
Ignition
Barry-is-correct,-the-acc-is-mainly-for-the-use-of-a-stereo-to-listen-to-while-you-work-on-you're-truck-so-you-won't-burn-your-points-up.
Old Oct 4, 2002 | 07:42 PM
Dustydude's Avatar
Dustydude
Ignition
JohnnyRanger
Feb 13, 2015 07:05 PM
HD
Aug 15, 2011 02:32 PM
ssj7kids
13
May 6, 2008 11:09 PM
Exposed
Electrical Systems/Wiring
Mar 27, 2007 01:56 PM
Beast12
Jul 30, 2004 10:16 PM
