Yes, the positions on the switch are as you described. And your accessories will work on either position. You must have your heater hooked up to a hot source of power( live all the time). If you have a wiring diagram of the 51 series, I'd check it again. Your harness should have a wire right off the switch to feed power over to the heater.
